Toyota LSD Carrier in an R200. Is it possible?
Zed
I recently picked up this LSD Differential for the low, low price of $25.00,
(the guy didn't know what it was) and I am pretty sure it came from a 198x
Toyota Celica GT-S or a Supra. I've only had time to pull off the rear cover,
so I don't really know anything like Ring Gear bolt size or stub axle teeth
and stuff like that. (There are no markings that I can find on the case.)
My question is this: Can this carrier be put into an R200?
Thanks!
Im pretty certain that this is an R230 diff, with a 230mm ring
gear, which I doubt will fit into an R200 (200 mm carrier assmbly)
but you could make custom flanges for the datsun axels to
line up... have you tried to line up a datsun axel?
My guess is you could grind off the extruded area of the
axel flange, and hold up the datsun axels and redrill them
to fit and bolt them up, and mounting wouldnt be too
difficult, you could welt a L flange onto the mustach
bar to allow mounting....
I have seen some of the newer infinity LSD's and this looks
alot like those (R230's) maybe they are made by Fuji Heavy
Industries, the company that makes R200's for Nissan (also
R's in Suburu's too, R160's)
Anyways hope these Ideas help.... it would be totally
slick and envious if you could use this Supra LSD on your
Z!
Dan
dannadeau2112@hotmail.com
