April 3, 200322 yr Author comment_32491 MR C. They aren't actually charging you too much. There are thresholds and once you cross it there is a standard rate charged. If, like in my case, they entered the tare weight over 1500 then you would be getting charged too much. I don't know the exact thresholds but one of them is 1500.Cheers Link to comment https://www.classiczcars.com/forums/topic/5405-tare-weight/?&page=3#findComment-32491 Share on other sites More sharing options...
April 3, 200322 yr comment_32499 Quote Originally posted by That Ozzy Guy Lachlan, if I remember right, the tech sheet I had from the RTA rated the 240K as 1200 tare weight. 350 Chev anyone??? Don't tempt me. Link to comment https://www.classiczcars.com/forums/topic/5405-tare-weight/?&page=3#findComment-32499 Share on other sites More sharing options...
April 9, 200322 yr Author comment_33155 Guys in Aus, I need your help again. I need to find out the Tare Weight as per the manual originally released by Nissan for an automatic 240Z. The automatics weighed more so I might be able to get through engineering with a 305.Please help.Cheers Link to comment https://www.classiczcars.com/forums/topic/5405-tare-weight/?&page=3#findComment-33155 Share on other sites More sharing options...
April 9, 200322 yr comment_33193 Don't know if it would help you, but NISSAN sources usually quoted that the Auto transmission versions were 25kg heavier than their Manual trans equivalents.Good luck,Alan T. Link to comment https://www.classiczcars.com/forums/topic/5405-tare-weight/?&page=3#findComment-33193 Share on other sites More sharing options...
April 9, 200322 yr Author comment_33194 That helps me alot actually Alan. I've made so many calls today and I'm getting the impression that the automatics weighed 1044 which means I can stick a 305 Chev in it and then stroke it after it's engineered.However I still need to get concrete evidence from a Nissan publication stating that weight for an engineer to aprove it. Cheers Link to comment https://www.classiczcars.com/forums/topic/5405-tare-weight/?&page=3#findComment-33194 Share on other sites More sharing options...
April 9, 200322 yr comment_33200 George,I'll have to have a dig through my stuff and see if I have it on an "official" publication.I'm thinking that it might be stated on one of the original sales brochures - but most of mine are the Japanese ones.What year and model is your car again? It will undoubtedly help if the right year and market version correspond with your application.I'm off to have a dig. Better than working.Alan T. Link to comment https://www.classiczcars.com/forums/topic/5405-tare-weight/?&page=3#findComment-33200 Share on other sites More sharing options...
April 9, 200322 yr comment_33201 George, I have here a copy of the service manual and nissan parts catalogue for the 240Z. The weight is only listed (as far as i can tell) as being 1025kg (2260lb). However there is a weight listing for the HLS30-U(Canadian/American LHD 240z?) as being 1044kg (2300lb) not sure if it helps, but if it does I can scan and email you a copy of the relevant page.Just to muck it up even fu rther, I have a brochure for the Australian 240Z's listing the weight as 2260.00lbs.Maybe its time for a rear light and compliance plate change, and we have ourselves a 260? The guys at motor vehicle registry don't have the rep for being the sharpest knives in the drawer. Link to comment https://www.classiczcars.com/forums/topic/5405-tare-weight/?&page=3#findComment-33201 Share on other sites More sharing options...
April 9, 200322 yr comment_33205 I can confirm for you 1040kg is the registered weight of an auto 240z (coupe) in NSW I have papers in Hand rego papers for 2000 at Glenbrook for my 12/71 auto.took all evening to find the paperscheersSteve:classic: Link to comment https://www.classiczcars.com/forums/topic/5405-tare-weight/?&page=3#findComment-33205 Share on other sites More sharing options...
April 9, 200322 yr Author comment_33206 Anything to get away from work Alan. My car is a 1972 Australian delivered model and we're looking for an automatic version weight if possible. Chris, unless there is something about the automatic model with a higher weight I wouldn't bother. The aim is to get it past 1040 and the registry doesn't really care about the source but if it was Nissan it would make things so much easier. Thanks guys, I appreciate your help. Link to comment https://www.classiczcars.com/forums/topic/5405-tare-weight/?&page=3#findComment-33206 Share on other sites More sharing options...
April 9, 200322 yr Author comment_33207 Quote Originally posted by sjcurtis I can confirm for you 1040kg is the registered weight of an auto 240z in NSW I have papers in Hand rego papers for 2000 at glenbrook for my 12/71 auto.took all evening to find the paperscheersSteve:classic: First you find me my car and now...Now how did you get that weight Steve? Link to comment https://www.classiczcars.com/forums/topic/5405-tare-weight/?&page=3#findComment-33207 Share on other sites More sharing options...
April 9, 200322 yr comment_33208 off my auto rego paper, so NSW Motor transport know the weights. Link to comment https://www.classiczcars.com/forums/topic/5405-tare-weight/?&page=3#findComment-33208 Share on other sites More sharing options...
April 9, 200322 yr Author comment_33209 Hmm, another call to their tech department is in order. I've spoken to them a few times and they've even faxed me their tech sheets which state the weight for the 240Z 'sedan'. There was no distinction between manual or automatic.Thanks Steve, I'll be harassing them tomorrow again. Link to comment https://www.classiczcars.com/forums/topic/5405-tare-weight/?&page=3#findComment-33209 Share on other sites More sharing options...
