Posted March 31, 200322 yr comment_32120 I am looking for a pair of Z camber plates.I would prefer the type that take the original bolt pattern.Thanks,Ed Palmer Link to comment https://www.classiczcars.com/forums/topic/5409-camber-plates-for-280z/ Share on other sites More sharing options...
March 31, 200322 yr comment_32129 Unfortunately, I haven't seen the camber plates that bolt up to the stock mounting holes in years... I know someone who has a set on his ITS car, but right now I can't remeber who even made them back then... The closest you can come to them would be the camber adjustment kit from MSA, which is nothing more than a block of urethane that take the place of the "top hat" on the strut...They don't give you much adjustment unless you use them in conjunction with the adjustable camber bushings...One place you could try would be this one, as I'm not sure what kind of camber plates they offerhttp://www.zcarperformance.com/Hmm, seems I spoke too soon. MSA has the camber plates you are looking for, but they are only available in conjunction with the coil-over kit they sell(900 bucks).... but then, someone has to be supplying them with the parts for the coil-over kit...:devious: Link to comment https://www.classiczcars.com/forums/topic/5409-camber-plates-for-280z/#findComment-32129 Share on other sites More sharing options...
April 1, 200322 yr comment_32167 Try http://www.daveturner.com/ he offers some plates for stock setups. Link to comment https://www.classiczcars.com/forums/topic/5409-camber-plates-for-280z/#findComment-32167 Share on other sites More sharing options...
