Posted April 1, 200322 yr comment_32153 Bored & stroked to 2.8 litres, fully ballanced & fully reconditioned with flat top pistons, N42 ported head, high volume oil pump, heavy duty valve springs, 38/68 cam, electronic dizzy, RPM heavy duty clutch kit, light flywheel, twin SU's with Pipercross air filter & SWR mandrel bent extractors. Has been fitted to car & just run in.$2900. Link to comment https://www.classiczcars.com/forums/topic/5414-l24-big-block-in-oz/ Share on other sites More sharing options...
April 2, 200322 yr comment_32295 A few questions:where is the power made? [rev range etc]Compression ratio?Estimated flywheel power?Why are you selling?Can the engine be seen running in car?Does engine come with all extras like alternator, loom etccheers, Link to comment https://www.classiczcars.com/forums/topic/5414-l24-big-block-in-oz/#findComment-32295 Share on other sites More sharing options...
