  • 5 weeks later...
The shop is now warm enough to to fiberglass, the CA glue stiffened the panels up quite a bit so I only used one sheet of glass mat for the job, 2nd pic is the wax paper over the door used as a mold, 4th pic you can see I glassed up to with in an inch and a half of the edge so when the leather edge wraps around it will be easier to glue and staple.
