Posted March 20, 20169 yr comment_489683 Anyone have a home plating kit and nothing to plate? I've got a radio chassis that needs replating. It doesn't need to be perfect. Name your price. Link to comment https://www.classiczcars.com/forums/topic/54252-i-need-radio-chassis-zinc-chromate-plated/ Share on other sites More sharing options...
March 20, 20169 yr comment_489725 I would help if I could, but I don't have my system up and running yet. Have you thought about Contacting Norm at Zeddsaver. He plated some stuff for me, he was reasonable... Link to comment https://www.classiczcars.com/forums/topic/54252-i-need-radio-chassis-zinc-chromate-plated/#findComment-489725 Share on other sites More sharing options...
March 25, 20169 yr comment_490410 Usually not that expensive to go to a professional plater. I spoke to someone doing a home kit and they said it was a massive hassle for hobby items like this and they would just outsource because you get a better job done and it's not very expensive when compared to other finishes like Chrome. Link to comment https://www.classiczcars.com/forums/topic/54252-i-need-radio-chassis-zinc-chromate-plated/#findComment-490410 Share on other sites More sharing options...
March 25, 20169 yr comment_490423 Part of the problem with the hobby plater is the larger the surface area the larger power source you need. Also agitation and the shape of the part complicates getting a good even coat on it. I agree, I think it would cost more to ship if you can't get it done locally on the islands than to actually have it plated Link to comment https://www.classiczcars.com/forums/topic/54252-i-need-radio-chassis-zinc-chromate-plated/#findComment-490423 Share on other sites More sharing options...
March 25, 20169 yr comment_490428 Call the guys at Ztherapy. They do this kind of thing weekly. Mike Link to comment https://www.classiczcars.com/forums/topic/54252-i-need-radio-chassis-zinc-chromate-plated/#findComment-490428 Share on other sites More sharing options...
April 5, 20169 yr Author comment_491725 ok so Norm is out of commission from a rollover accident and ztherapy said they send it out to a place in portland. Any other suggestions? I'de like to buy a copy cad kit myself but if someone has a home kit, it would be nice to see firsthand what kind of job the home kits do. There are some people out there that have upgraded to a larger rectifier and can do bigger pieces like this with their kits. Link to comment https://www.classiczcars.com/forums/topic/54252-i-need-radio-chassis-zinc-chromate-plated/#findComment-491725 Share on other sites More sharing options...
April 5, 20169 yr comment_491727 DIY results were well documented by Grannyknot (c/w lots of pix) a few months back (use the search function). Additional comments were offered there by Nix240 and Patcon, IIRC. While what you want to to achieve is do-able, I think that the phrase, 'Your results may vary' applies here. A large, angular piece like the radio chassis may offer special challenges because of 'masking' in and around the corners. Link to comment https://www.classiczcars.com/forums/topic/54252-i-need-radio-chassis-zinc-chromate-plated/#findComment-491727 Share on other sites More sharing options...
April 5, 20169 yr comment_491728 3 minutes ago, Namerow said: While what you want to to achieve is do-able, I think that the phrase, 'Your results may vary' applies here. A large, angular piece like the radio chassis may offer special challenges because of 'masking' in and around the corners. Exactly right! It would take a good setup and an experienced DIYer to get decent results Link to comment https://www.classiczcars.com/forums/topic/54252-i-need-radio-chassis-zinc-chromate-plated/#findComment-491728 Share on other sites More sharing options...
April 14, 20169 yr Author comment_492609 ok, Norm is back at work. I sent him a box of radio parts. I will post pictures of what he sends back Now all i need is some white labels this size because I don't think anyone reproduces these yet. Edited April 14, 20169 yr by hr369 Link to comment https://www.classiczcars.com/forums/topic/54252-i-need-radio-chassis-zinc-chromate-plated/#findComment-492609 Share on other sites More sharing options...
April 14, 20169 yr comment_492653 Contact Mike @ Banzai Maybe he can make some for you you have mail... Link to comment https://www.classiczcars.com/forums/topic/54252-i-need-radio-chassis-zinc-chromate-plated/#findComment-492653 Share on other sites More sharing options...
April 17, 20168 yr Author comment_492891 On 4/14/2016 at 9:19 AM, Patcon said: Contact Mike @ Banzai Maybe he can make some for you you have mail... Making my own. Just gotta find some labels this size to print. Link to comment https://www.classiczcars.com/forums/topic/54252-i-need-radio-chassis-zinc-chromate-plated/#findComment-492891 Share on other sites More sharing options...
April 17, 20168 yr comment_492893 Awesome, going to make other ones like TM-1081ZB(S)? Link to comment https://www.classiczcars.com/forums/topic/54252-i-need-radio-chassis-zinc-chromate-plated/#findComment-492893 Share on other sites More sharing options...
