Posted March 21, 20169 yr comment_489887 So what I've seen so far is that this is a regular occurrence. When I bought the car the turn signals worked but as soon as it started raining they went out. The lights don't flash on the dashboard nor the outside. But when I turn my hazards on, they show on the dash and outside. What could this be? Link to comment https://www.classiczcars.com/forums/topic/54370-turn-signals-dont-work-80-280zx/ Share on other sites More sharing options...
March 21, 20169 yr comment_489888 clean bulbs end and sockets starting with the front. Link to comment https://www.classiczcars.com/forums/topic/54370-turn-signals-dont-work-80-280zx/#findComment-489888 Share on other sites More sharing options...
March 22, 20169 yr comment_489970 Also replace rubber parts of your light units... its leaking. Link to comment https://www.classiczcars.com/forums/topic/54370-turn-signals-dont-work-80-280zx/#findComment-489970 Share on other sites More sharing options...
March 22, 20169 yr Author comment_489986 On 3/22/2016 at 10:59 AM, Martzedcars said: Also replace rubber parts of your light units... its leaking. Does that explain why the lights don't work on the dash? Link to comment https://www.classiczcars.com/forums/topic/54370-turn-signals-dont-work-80-280zx/#findComment-489986 Share on other sites More sharing options...
March 25, 20169 yr comment_490416 When moisture shortcircuit the bulbs the cligno shuts down and none of the lights wil flash including the ones on your dash! So, Yes! Link to comment https://www.classiczcars.com/forums/topic/54370-turn-signals-dont-work-80-280zx/#findComment-490416 Share on other sites More sharing options...
March 25, 20169 yr comment_490418 BTW Hazards lights are controlled (I think) by a heavy-er cligno.. because now it has to work with twice as much lampbulbs Edited March 25, 20169 yr by Martzedcars Link to comment https://www.classiczcars.com/forums/topic/54370-turn-signals-dont-work-80-280zx/#findComment-490418 Share on other sites More sharing options...
March 26, 20169 yr comment_490520 On 3/21/2016 at 5:18 PM, bcharmane said: So what I've seen so far is that this is a regular occurrence. When I bought the car the turn signals worked but as soon as it started raining they went out. The lights don't flash on the dashboard nor the outside. But when I turn my hazards on, they show on the dash and outside. What could this be? Get a multimeter and start measuring ! Turn on the turn signals and measure if you have a 12v pulse going to the turn signals. Put Multimeter on 12 DC So: Put left turn signal on, and start measuring on the connectors of the front and rear left light bulb. You should measure at least a max peak of 9 volts. If not, go measure voltage @ the flasher relay. This way you can trace the problem. Link to comment https://www.classiczcars.com/forums/topic/54370-turn-signals-dont-work-80-280zx/#findComment-490520 Share on other sites More sharing options...
