April 20, 20168 yr Author comment_493157 Hey , the CCZC app let me attach a photo and it worked Sent from my iPhone using Classic Zcar Club Link to comment https://www.classiczcars.com/forums/topic/54393-seat-upgrade-350z-seats/?&page=5#findComment-493157 Share on other sites More sharing options...
April 20, 20168 yr comment_493169 It doesn't give me the "camera" option! And I've had to sign in 2 or 3 times since installing it. Had to dig out my file showing the pword. Working out the bugs I'm sure, I'll wait another day or so. Link to comment https://www.classiczcars.com/forums/topic/54393-seat-upgrade-350z-seats/?&page=5#findComment-493169 Share on other sites More sharing options...
May 8, 20168 yr Author comment_494516 Sorry I haven't kept up with thread very well. I usually am sitting in hotels with time to type, but be home more often-a good thing! I have had the seats mounted in and have been driving around for weeks. I really do like the seats as far as comfort level. Making seat position changes at my finger tips is nice. Reaching back to turn the "knob" on my old seats was awkward. Changing on the fly makes trying new positions of comfort easy. Wiring couldn't be any easier . The connector is at the front of the seat with four connecting tabs. I just wired hot and ground and done. The other two tabs are the heat, but haven't done that yet. I have extra fuse boxes in my car so I was able to draw power thru a separate fuse and grounded things right at the seat mount. With my seat mounting I was able to keep the seat low enough to sit in there with a helmet on. I can't have the seat in the most upright position with a helmet on, but just a slight recline I fit in there well. I had my buddy sit in there and he is 6'4", and he felt comfortable enough( NO HELMET). The seats(especially driver's) probably does NOT go back as far as original, but very close. With seat all the way back and the playing with the recline, my friend felt very comfortable. He actually has more height clearance in my car than his own completely stock 71. He did use a thicker headliner and has new seat cushions that are not broke in. The Wesco seats belts are a great fit, but I thought it funny that the inertia reels are as touchy as my old Nissans. I think I will take the above advice and tether the inboard seat frame to the floor. The threads I've seen on this the guys have not kept the plastic on the sides of the seat, but it can be done with some trimming. I didn't want to look at seat mechanicals when I opened the door. It definitely makes for a more finished look to leave the trims on. Non-power seats is probably the better option for weight and for greater leg room on the driver's side, but this would probably only be a problem for very tall folks. And how many times are you going to use the adjustment on the passenger side. The passenger seat does have a quick release to tilt the back forward. It will make it easy to grad something in the back from the passenger side. A more forward head rest would also be nice. Most newer seats have the head rest canted forward, which I like. I might consider a slight tweak on the headrest posts-later. I will post more pics when I get my camera out. My I phone is not cooperating Link to comment https://www.classiczcars.com/forums/topic/54393-seat-upgrade-350z-seats/?&page=5#findComment-494516 Share on other sites More sharing options...
May 8, 20168 yr comment_494546 Steve, did you take any pics of the seat mount adapters you built? I haven't got to it yet but I will have to do the same thing. Yeah the Wesco inertia reels are really touchy, everyone who gets in the car gets the warning, " Now pull your seat belt out VERY slowly" Chris Link to comment https://www.classiczcars.com/forums/topic/54393-seat-upgrade-350z-seats/?&page=5#findComment-494546 Share on other sites More sharing options...
May 8, 20168 yr Author comment_494549 Well the uploader finally worked. You can see I had runners 3/16" flat stock from mount to mount and horizontal to go seat frame side to side. That was all welded together to make the mount brackets and of course welded to the seat frame. I need to pull them back out for paint and will take more pics Link to comment https://www.classiczcars.com/forums/topic/54393-seat-upgrade-350z-seats/?&page=5#findComment-494549 Share on other sites More sharing options...
May 8, 20168 yr Author comment_494550 Another successful upload!!! you can see what I trimmed in this photo Link to comment https://www.classiczcars.com/forums/topic/54393-seat-upgrade-350z-seats/?&page=5#findComment-494550 Share on other sites More sharing options...
May 8, 20168 yr comment_494552 Love it, clean and simple. Is that a second adjustable knob on your brake proportioning valve? Link to comment https://www.classiczcars.com/forums/topic/54393-seat-upgrade-350z-seats/?&page=5#findComment-494552 Share on other sites More sharing options...
May 9, 20168 yr Author comment_494558 Parking brake and proportioning valve . Another obstacle to overcome with these seats. Link to comment https://www.classiczcars.com/forums/topic/54393-seat-upgrade-350z-seats/?&page=5#findComment-494558 Share on other sites More sharing options...
May 9, 20168 yr comment_494572 Madkaw - Those seats are awesome and look like they belong in there! I think the curves and style of those seats fit well with the 240z interior. Link to comment https://www.classiczcars.com/forums/topic/54393-seat-upgrade-350z-seats/?&page=5#findComment-494572 Share on other sites More sharing options...
May 9, 20168 yr comment_494585 Agreed. Those look very nice. Link to comment https://www.classiczcars.com/forums/topic/54393-seat-upgrade-350z-seats/?&page=5#findComment-494585 Share on other sites More sharing options...
June 8, 20213 yr comment_623029 On 5/8/2016 at 7:03 PM, madkaw said: That was all welded together to make the mount brackets and of course welded to the seat frame. Madkaw, I started on my seat project. I have 350z power seats. I’m worried about welding the frame to the seat tracks. There are plastic parts inside the tracks and that’s a lot of heat. Advice? Link to comment https://www.classiczcars.com/forums/topic/54393-seat-upgrade-350z-seats/?&page=5#findComment-623029 Share on other sites More sharing options...
June 8, 20213 yr Author comment_623031 Be careful? As you can see from my pics I had to take the seats apart to do this. Don't remember melting anything . I've slept too many days to remember specifics Link to comment https://www.classiczcars.com/forums/topic/54393-seat-upgrade-350z-seats/?&page=5#findComment-623031 Share on other sites More sharing options...
