Email logins are now active ×
240z - 17" ?????
ritual_funk
Your answer is yes, as long as the correct offset is used. I run 17x8 fr. & 17x9 rear, with 215-40 & 235-40 tires respectively. In addition I've shortened all four struts 1.5" and added coil-overs. Once you get into wider rims you will require coil-overs for clearance.
