You have the wrong 240Z grille for your 240Z. Yes they are different. You have one with the short middle horizontal bar and you should have the one with four long bars at the top and three middle length bars. That grille has the vertical locating tabs on the outer lower mount.
 You can see them in my photos. The second type is a little difficult to see clearly because a 280Z grille is laying on top. I can post some better photos of the two ypes later.
I have the brackets if you want them. Just drill out the rivits and replace the bottom mounts.
Edited by EuroDat
Typo
I knew it couldn't be the body lol!!
That would be great, I'll PM you. Thanks!
  On 1/23/2017 at 10:24 PM, EuroDat said:
Here is a photo of the two you need and one of the type you have now. If you want them, they are yours. Pm me.
Thanks so much, Pm sent!
  On 1/24/2017 at 6:42 PM, EuroDat said:
The parts are on the way. You should have them over a week.
Thank you for the grill mounts, I just received them!
You should be able to drill out the rivits and fit the correct bracket for your situation. The rivit holes should line up. I would try aluminium rivits because the vertical bars are aluminium and hard steel can distort the hole.
And now some pictures of the finished job;)
Guest
Reply to this topic...
