Couple of things i can think of for that.
If its a case of just wanting the shine, you can lightly sand your plastic wood wheel, then get an epoxy based clear coat sprayed on (as long as its got the UV modifier it should work well) Speak to a boatbuilder or spray painter.
The dash firm near us does steering wheel restos, and can put all sorts of finishes on it pearl etc, so a wood finish should be a doodle for them.
I went to the local sushi bar after reading cats original post, and it had a laminex top :(
  Quote
If its a case of just wanting the shine, you can lightly sand your plastic wood wheel...
Thanks for that but what do you mean by plastic wood wheel?
The "wooden" 240z steering wheel is infact an epoxy based plastic (ie a thermosetting one) not real wood? Not sure about all of them, but mine sure is given the small cracks that it has in it.
