Hi,
Does anyone know where i could get a set of pistons (12010-P7917) and rings (12038-P7910)?  Everything i have read says these Nissan parts have been discontinued and I am just looking for a good replacement.  Thank you for any assistance.
Clay
https://www.classiczcars.com/forums/topic/54928-l28-1-mm-flat-top-pistons/
ITM Pistons are fantastic.....I don't like their rings. I use Total Seal Rings with the ITM pistons.....just toss their rings. These are 1 mm ITM's in an L28 block. Nissan may still carry the .040 over (1 mm) rings. If so, you can use them with the ITM's.
Awesome info guys thank you very much.  I think I've narrowed what is needed down to two part numbers:
ITM Pistons - RY6134-040 (piston kit for a 87mm bore)
Total Seal Rings - T2416 (replacement rings for 87mm bore)
Thanks again.
Clay
