11 minutes ago, zmanoside said:
Hosomi said they were ITB pistons
But are they?  Should be marked.  If they're not then it's not the engine Hosomi put together.
Is this the ITB mark?  Don't know much myself.  Edit - did you mean ITM?
Edited by Zed Head
I probably did mean ITM. I knew it was IT something...I looked at Datsun spirit website and saw a picture of there flat top Pistons they have for sale. The is a mark on top of the piston that say STD. This same mark is on each of the Pistons I have in the box.
STD is stamped on the top of almost all standard size pistons, of any brand.  The shape of the letters and stamp depth might be a clue though.
I found a picture of what are purported to be ITM pistons, on the CaliforniaDatsun site.  Salt grain.  They don't show that odd trademark.  It looks like a T and a K to me, with maybe an odd-shaped "i" in between.
But here's the ITM pictures.  from here - https://www.californiadatsun.com/cylinder-head-parts/flat-engine-piston-set.html
Well, thanks for providing the puzzle.  Beat's the heck out of a crossword.
You might have your builder compare dimensions of the new pistons to those.  People often pick a piston to swap in based on pin diameter and height and just make it work.  Honda 500 pistons for example, seem to be popular.  Maybe they missed skirt length, or overall piston height, and it banged off of the crankshaft.  Do you have the skirt pieces?  Look for impact marks.
That Taiwan site does have some Nissan pistons if you use the drop-down menus on the left, on the Products page.  More of a curiosity at this point, but might offer a clue.
http://www.tikparts.com/index.php?option=product&lang=en
