Posted April 10, 20169 yr comment_492208 http://huddleston240z.weebly.com My friend, Dave, is in the process of restoring a 1971 240z for a second friend, Iain. He is doing a great job of documenting the process in the above blog, along with lots of photos. I thought some might find this interesting. This afternoon, we're going to tackle spindle pins. This is a job I have not yet done on my 240z, so I thought it would be interesting to help Dave out, to see if the spindle pin and bushing replacement is something I might want to tackle next winter. Link to comment https://www.classiczcars.com/forums/topic/55239-restoration-blog-iains-1971-240z/ Share on other sites More sharing options...
April 10, 20169 yr comment_492227 I believe that job is a rite of passage for any Z owner. They could go either way, simple and easy or really, really hard. Lots of threads about spindles here. Have fun and keep us posted. Link to comment https://www.classiczcars.com/forums/topic/55239-restoration-blog-iains-1971-240z/#findComment-492227 Share on other sites More sharing options...
April 11, 20169 yr comment_492397 I believe that job is a rite of passage for any Z owner. They could go either way, simple and easy or really, really hard. Lots of threads about spindles here. Have fun and keep us posted. I had one of each ... Link to comment https://www.classiczcars.com/forums/topic/55239-restoration-blog-iains-1971-240z/#findComment-492397 Share on other sites More sharing options...
April 11, 20169 yr Author comment_492405 We had one of each as well! We were able to hammer one out using a drift without too much effort. The second spindle pin wouldn't budge. We cut the spindle pin in two places to seperate the strut assembly from the rear control arm and Dave will be taking the piece to a local shop to have the spindle pin pieces pressed out. Overall, not too bad. Link to comment https://www.classiczcars.com/forums/topic/55239-restoration-blog-iains-1971-240z/#findComment-492405 Share on other sites More sharing options...
April 11, 20169 yr comment_492411 Mine took a lot more than just the press. Heat, ATF fluid, and over 60 tonnes of pressure... Link to comment https://www.classiczcars.com/forums/topic/55239-restoration-blog-iains-1971-240z/#findComment-492411 Share on other sites More sharing options...
April 12, 20169 yr comment_492455 That blog is great! I have already enjoyed reading it and have only gotten to a few posts. On the topic of spindle pin removal, there are several well documented threads of pain and misery, mine is one of them below. Good luck to him with it and be careful working on them. http://www.classiczcars.com/topic/45649-spindle-pin-woes/ Link to comment https://www.classiczcars.com/forums/topic/55239-restoration-blog-iains-1971-240z/#findComment-492455 Share on other sites More sharing options...
April 18, 20169 yr Author comment_492959 Dave emailed me and apparently the spindle pin we had to cut took a torch and a 60 tonne press to extract from the control arm and strut assembly! On the bright side, if only cost $25 to have the shop extract the spindle pin. Link to comment https://www.classiczcars.com/forums/topic/55239-restoration-blog-iains-1971-240z/#findComment-492959 Share on other sites More sharing options...
April 18, 20169 yr comment_492966 Sometimes, they just don't want to come out. My '78 required a giant press as well. Glad Dave got it out. Link to comment https://www.classiczcars.com/forums/topic/55239-restoration-blog-iains-1971-240z/#findComment-492966 Share on other sites More sharing options...
April 22, 20169 yr comment_493308 That was $25 well spent. The time and misery of getting them out when they are really stuck exceeded $25 in about 25 minutes. Link to comment https://www.classiczcars.com/forums/topic/55239-restoration-blog-iains-1971-240z/#findComment-493308 Share on other sites More sharing options...
June 21, 20168 yr Author comment_497266 Just a bump to the thread. Dave is now on post #21. He's done a great job of documenting the process. We should be ready to install the engine and trans in the next week or so. Link to comment https://www.classiczcars.com/forums/topic/55239-restoration-blog-iains-1971-240z/#findComment-497266 Share on other sites More sharing options...
