Posted April 10, 20169 yr comment_492280 I dont know if i should ask this on a different forum but I am trying here first. If i am wrong please direct me to the right forum. When I got the 27 spline 280z stub axles, in spite of my best and some what limited efforts, I damaged the top threads. I want to buy a die to chase the threads for the new nuts. I don't know what size to get. I tried the search feature, and we all know how much fun that is, but nothing came up that helps. I tried two places on line that sell the nuts and got two different answers. The size is supposed to be the same for 240-280 series. Anybody know or have a link to where the info is? I did get the stub axels and cv shafts out of a 280zx turbo but they are only 25 splines and the nuts weren't even staked. I wonder why Nissan put the so called weaker splined axels on a car that was supposed to have more power than the std 280zx? Anyway I got the right stub axels and am going with the CV conversion kit from Futofab (wolf racing) so I am gonna have a surplus pile of stuff to sell at the end of the project, whenever that is. They said their kit has been improved and upgraded so this is gonna be a good thing. Thanks for any help Link to comment https://www.classiczcars.com/forums/topic/55248-stub-axle-thread-pitch-and-diameter/ Share on other sites More sharing options...
April 10, 20169 yr comment_492283 They are 20 x 1.5 thread pitch. Same on 70-83 stub axles regardless of splines. Link to comment https://www.classiczcars.com/forums/topic/55248-stub-axle-thread-pitch-and-diameter/#findComment-492283 Share on other sites More sharing options...
April 10, 20169 yr Author comment_492286 Thanks, I will start shopping for one tonite. I am waiting for my coilovers from technotoy so I want to be ready to put the rears together when they get here. Thanks again Link to comment https://www.classiczcars.com/forums/topic/55248-stub-axle-thread-pitch-and-diameter/#findComment-492286 Share on other sites More sharing options...
April 10, 20169 yr comment_492291 38 minutes ago, jl240z said: I did get the stub axels and cv shafts out of a 280zx turbo but they are only 25 splines and the nuts weren't even staked. I wonder why Nissan put the so called weaker splined axels on a car that was supposed to have more power than the std 280zx? Nissan used a self-locking nut on the ZX's, so no need to stake anymore. You should too, they're available. As for damage, don't overlook that the damaged portion doesn't do any work once the nut is past it. If the threads won't damage the nut, then you might as well leave them that way. The smaller axle question has been raised before. Could be that they redesigned it and removed the stress risers that existed in the 240Z design. It would be interesting to see the two side-by-side. Or that the ZX suspension isn't as hard on the axles as the Z's. Link to comment https://www.classiczcars.com/forums/topic/55248-stub-axle-thread-pitch-and-diameter/#findComment-492291 Share on other sites More sharing options...
April 10, 20169 yr Author comment_492295 I did place the ccmpanion flange of the 280z over the stub axle of the turbo and there is a very visable difference showing how much smaller the 25 spline is. I don't think I will have to worry about breaking anything but stuff happens sometimes. It is probly more likely to break something with the limited slip I would think. Any advantage to save me when I screw up is nice, Notice I said when, not if? I wonder if in addition to torqueing to the correct ft. lbs, if liberal red lock tight is enough instead of staking the nut. I can reuse the nuts off the turbo but they don't have a lip to stake at the top like the 280z nuts had. It is probly smart money to buy new ones and I would have already if I could find then. Anybody know a vendor besides Nissan who sells the right nuts? unsalted of courss Link to comment https://www.classiczcars.com/forums/topic/55248-stub-axle-thread-pitch-and-diameter/#findComment-492295 Share on other sites More sharing options...
April 10, 20169 yr comment_492304 I was thinking about the 240Z axle weak point. Borrowed a 280ZX axle picture from here - https://www.fototime.com/ftweb/bin/ft.dll/detailfs?userid=7DC317B08EDB4B2EA837F708D07C9769&ndx=19&albumid=180EC34916C34BD7850ED1A4EBA6F840&pictureid=0F5C07D338644ADBAE151D14EE4BFDF1 and the 240Z from here - http://forums.hybridz.org/topic/49194-differential-cv-lsd-hp-torque-r160-r180-r200-r230-diff-mount/ and here - http://www.thezstore.com/page/TZS/PROD/23-5020R Notice that the same tiny nut is used, leaving a big stress riser at the base. The breaks occur on the same diameter. The larger splined section doesn't seem to be any advantage in strength. Maybe why they went back to 25 spline. It does allow a bigger bearing though. Even the big 300ZX 39 spline axles use a small nut diameter. http://www.modern-motorsports.com/stub-axles.html Edited April 10, 20169 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/55248-stub-axle-thread-pitch-and-diameter/#findComment-492304 Share on other sites More sharing options...
April 10, 20169 yr comment_492306 Here's a nut source - http://www.thezstore.com/page/TZS/PROD/23-4573 Link to comment https://www.classiczcars.com/forums/topic/55248-stub-axle-thread-pitch-and-diameter/#findComment-492306 Share on other sites More sharing options...
April 10, 20169 yr comment_492310 The first pic is the 240z stub axle, the splines end in sharp edge, second pic is a 280zxt stub, they rounded the splines to flow into the threads. I don't know if that helps but some guys are dumping serious torque into 280zxt stubs without problems, perhaps a better quality of steel, better tempering? Link to comment https://www.classiczcars.com/forums/topic/55248-stub-axle-thread-pitch-and-diameter/#findComment-492310 Share on other sites More sharing options...
April 10, 20169 yr comment_492314 Thanks, that's the picture I wanted to see. And there's not a lot of info there really. I wonder if other things helped also like the thickness of the washer under the nut. Maybe even the shape of the nut's clamping surface. I think the breakage is more a flexing/fatigue break, than an actual yield break. Could be all of the people switching to 280Z axles really just need to switch to 280ZX nuts and washers. grannyknot was in the process of installing ZX CV's. Not sure where he ended up. Link to comment https://www.classiczcars.com/forums/topic/55248-stub-axle-thread-pitch-and-diameter/#findComment-492314 Share on other sites More sharing options...
April 10, 20169 yr comment_492315 All they seem to have done for the later nut is incorporate the washer into the base of the nut. 240 nut and washer on the left, 280zx on the right. Zed, the CV axles are finished and ready to install, I just don't have a car ready to install them into yet. That's another year away. Link to comment https://www.classiczcars.com/forums/topic/55248-stub-axle-thread-pitch-and-diameter/#findComment-492315 Share on other sites More sharing options...
April 10, 20169 yr comment_492317 Seems like the ZX flanged nut would be stiffer than the Z assembly. Interesting stuff. Maybe it's more than just a lock nut. I dragged a CV axle and a u-joint halfshaft out the other day and measured them. But just realized I didn't measure both CV's so need to do it again. The one CV axle I measured was 1" shorter than the half-shaft. So, in my case, 1" for an adapter. Factory issue 1983 CV axles. I'll measure the other and add it to your thread, just for the record. Thanks for the pictures. Link to comment https://www.classiczcars.com/forums/topic/55248-stub-axle-thread-pitch-and-diameter/#findComment-492317 Share on other sites More sharing options...
April 11, 20169 yr Author comment_492324 4 hours ago, Zed Head said: Here's a nut source - http://www.thezstore.com/page/TZS/PROD/23-4573 4 hours ago, Zed Head said: Here's a nut source - http://www.thezstore.com/page/TZS/PROD/23-4573 Thanks, I will check it out. I am reading all the other postings on the stub axels. I too noticed the difference in the nuts. The zx turbo one has a slightly thinner base but the base is larger in diameter. Since I have them ill take the advice and try and clean up the boggered up threads before I buy the die and see how they thread onto the stub axels. Guys thanks for all the info so far its been a lot of help Link to comment https://www.classiczcars.com/forums/topic/55248-stub-axle-thread-pitch-and-diameter/#findComment-492324 Share on other sites More sharing options...
