Posted April 16, 20169 yr comment_492807 I need to source this front cross member hardware Norm @ Zeddsaver has it, but only on an exchange basis. I have looked through all my hardware but haven't been able to find them. Any of you guys parting cars have this hardware? The washers are more important than the bolts. Also size pitch and thread would be good to know if someone can check for me Link to comment https://www.classiczcars.com/forums/topic/55285-front-crossmember-hardware/ Share on other sites More sharing options...
April 16, 20169 yr Author comment_492810 Bolts are M10x1.25 but don't know the length... Link to comment https://www.classiczcars.com/forums/topic/55285-front-crossmember-hardware/#findComment-492810 Share on other sites More sharing options...
April 16, 20169 yr comment_492826 Is it just the bolts you are after or all the plates as well? They are just M10x1.25 as noted, maybe 30mm long. Grade 10.9 JIS for sure. Belmetric would have them. I wouldn't feel bad using SAE 3/8 Gr8 NF hardware either. At the local "Bolt supply house" the Gr8 fine hardware is all CAD plated and purdy too! Bonus. I have spares of the top/bottom plates if you need a set. Link to comment https://www.classiczcars.com/forums/topic/55285-front-crossmember-hardware/#findComment-492826 Share on other sites More sharing options...
April 16, 20169 yr Author comment_492847 @zKars Jim I am really after the plates. I probably have spare bolts and washers I could use but can't locate the "special washers" Link to comment https://www.classiczcars.com/forums/topic/55285-front-crossmember-hardware/#findComment-492847 Share on other sites More sharing options...
April 16, 20169 yr comment_492855 Oh! Well that's easy. Send me a note to z240@shaw.ca and I'll get a set in a box for you and send some pics! Link to comment https://www.classiczcars.com/forums/topic/55285-front-crossmember-hardware/#findComment-492855 Share on other sites More sharing options...
April 30, 20168 yr Author comment_493881 Got them a little while back Thanks, Jim @zKars Link to comment https://www.classiczcars.com/forums/topic/55285-front-crossmember-hardware/#findComment-493881 Share on other sites More sharing options...
April 30, 20168 yr comment_493907 On 4/16/2016 at 4:33 PM, Patcon said: @zKars Jim I am really after the plates. I probably have spare bolts and washers I could use but can't locate the "special washers" out of curiosity, what is so special about those washers? Link to comment https://www.classiczcars.com/forums/topic/55285-front-crossmember-hardware/#findComment-493907 Share on other sites More sharing options...
April 30, 20168 yr Author comment_493915 The "special washers" are what they call the oddly shaped plates. The bolts and lock washers are standard hardware Link to comment https://www.classiczcars.com/forums/topic/55285-front-crossmember-hardware/#findComment-493915 Share on other sites More sharing options...
