April 18, 20168 yr Author comment_492968 This is info I can use! I overlooked relay testing section in FSM and yes, I will get my own continuity/voltage tester for wiring and relay tests. I do need to learn how to use it and I can find someone to explain and/or show me. Also thank you for advice on desirable DC voltage. Will then try to retest all battery to pump components along power paths (with first attention to main relay and pump relay...they did click with every battery/power connect but need to be fully tested anyway). I will retest following wiring diagram from FSM and fuel pump circuit diagram. The ignition switch is the only component that has not gotten any testing to date...and I will remove it from steering column since I can't get to it's pins in place. Too old for body "twists" :=). So the journey begins. Thank you! Please wish me success. Doug Link to comment https://www.classiczcars.com/forums/topic/55289-fuel-pump-mystery/?&page=2#findComment-492968 Share on other sites More sharing options...
April 18, 20168 yr Author comment_492969 Just a side note: is there a "log off/out" for this site? Probably obvious but I don't see it. Link to comment https://www.classiczcars.com/forums/topic/55289-fuel-pump-mystery/?&page=2#findComment-492969 Share on other sites More sharing options...
April 18, 20168 yr comment_492970 I would go directly to the fuel pump relay. The ignition switch powers the ignition relay, and it everything else is working then your ignition switch is fine. Click on your user name, upper right corner of page, and a drop-down menu will open up. Link to comment https://www.classiczcars.com/forums/topic/55289-fuel-pump-mystery/?&page=2#findComment-492970 Share on other sites More sharing options...
April 18, 20168 yr Author comment_492982 Thanks for both directions! Link to comment https://www.classiczcars.com/forums/topic/55289-fuel-pump-mystery/?&page=2#findComment-492982 Share on other sites More sharing options...
May 4, 20177 yr comment_519900 Hi new to the forum I was wondering zed head if you know this: http://www.summitracing.com/parts/bck-203-0053?seid=srese1&gclid=CLH_xc2zlswCFYqPfgodHdkAug will work to replace the two in one relay under the driver side dash Link to comment https://www.classiczcars.com/forums/topic/55289-fuel-pump-mystery/?&page=2#findComment-519900 Share on other sites More sharing options...
May 4, 20177 yr comment_519901 25 minutes ago, utahS30z said: Hi new to the forum I was wondering zed head if you know this: http://www.summitracing.com/parts/bck-203-0053?seid=srese1&gclid=CLH_xc2zlswCFYqPfgodHdkAug will work to replace the two in one relay under the driver side dash What year 280Z? Link to comment https://www.classiczcars.com/forums/topic/55289-fuel-pump-mystery/?&page=2#findComment-519901 Share on other sites More sharing options...
May 4, 20177 yr comment_519902 1 minute ago, SteveJ said: What year 280Z? Yeah, itn't this the '77 and '78? Link to comment https://www.classiczcars.com/forums/topic/55289-fuel-pump-mystery/?&page=2#findComment-519902 Share on other sites More sharing options...
May 4, 20177 yr comment_519903 17 minutes ago, SteveJ said: What year 280Z? I just replied to a PM from utah. The images on Amazon look almost identical pin-wise, to the Nissan part. But the web sites all say it's for Volkswagen, and some say it won't work for a 280Z. https://www.amazon.com/Beck-Arnley-203-0053-Relay/dp/B000CB0DK4 Anybody want to compare pins? Trying to attach an image but I'm having CZCC web site problems. This is from Amazon. It's all that shows, CZCC says it's done loading. Maybe someone else can get it loaded. Edited May 4, 20177 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/55289-fuel-pump-mystery/?&page=2#findComment-519903 Share on other sites More sharing options...
May 4, 20177 yr comment_519907 The terminal designations are all the same. Nissan licensed the Bosch fuel injection system that was used in VWs, etc. The terminals for each half line up, but the wiring diagram shows the halves swapped. The EF section of the FSM shows the correct orientation with several figures starting at EF-54. It will most likely work. Link to comment https://www.classiczcars.com/forums/topic/55289-fuel-pump-mystery/?&page=2#findComment-519907 Share on other sites More sharing options...
May 4, 20177 yr comment_519908 1 hour ago, Zed Head said: I just replied to a PM from utah. The images on Amazon look almost identical pin-wise, to the Nissan part. But the web sites all say it's for Volkswagen, and some say it won't work for a 280Z. https://www.amazon.com/Beck-Arnley-203-0053-Relay/dp/B000CB0DK4 Anybody want to compare pins? Trying to attach an image but I'm having CZCC web site problems. This is from Amazon. It's all that shows, CZCC says it's done loading. Maybe someone else can get it loaded. I copy and pasted these from your link above without any trouble. Edited May 4, 20177 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/55289-fuel-pump-mystery/?&page=2#findComment-519908 Share on other sites More sharing options...
May 4, 20177 yr comment_519909 It showed up properly when I got back in to CZCC. It didn't show the whole picture before though. I'm having some weird issues with the site. I signed in from a phone just now and I can't figure out how to sign out. I'm permanently signed in, apparently. This post is from my computer though, because there's no cut and paste option on Android, as far as I can tell. The super phones aren't that super. I had to write in Notepad here while I waited to be able to sign in. Gotta be the NSA. On the double relay - Wouldn't be surprised if those plastic pillars on the side get in the way of the Nissan plugs. Could be why it won't "work". Cut them off and it should. That might be a significant find for future relay seekers. We've overlooked the basic question we usually ask though - are you sure it's the relay that's the problem? Might be spending on the wrong part. Link to comment https://www.classiczcars.com/forums/topic/55289-fuel-pump-mystery/?&page=2#findComment-519909 Share on other sites More sharing options...
May 4, 20177 yr comment_519910 Meh, he hijacked the thread. Link to comment https://www.classiczcars.com/forums/topic/55289-fuel-pump-mystery/?&page=2#findComment-519910 Share on other sites More sharing options...
