1971 HLS30-14938 "Lily" build
Patcon
On 1/21/2018 at 12:18 PM, Patcon said:
Evidently EPDM is the choice for brake fluid
Our Swiss friend on this site has a lot of expertise in the area of hydraulic seal materials and fluid compatibilities.  In fact, I think he commented on exactly this point a few years ago (try a search on 'epdm').  I think it may have been in a thread related to rebuilding the brake no-pressure sensor/switch.
Is this the one?
I need some help
I need a few of these brake line holders. I have the locking pieces but don't have enough brake line holders. I would prefer they are not badly beat up. If they have some rust it's not a problem. I will re-plate them here
Also I two different styles of mustache bar washers. Which is correct for a 240z? The upper ones with the crenelated rubbers on the bolts are the ones I suspect are correct. If so what are the other ones for?
I also need 2 of these. I dug through my whole shop and I can't find these. I am sure I have 3 pairs here but I can't locate them. I need the 2 little pieces that bolt to the bottom of the bar that crosses behind the differential. They hold the rear side of the rear swing arms in place
If you have any of these let me know or PM me and we can work out shipping and cost arrangements...
Edited by Patcon
  • 1 month later...
So the car had a turbo engine in it when I got it. I don't know if it ran. This is the fuel tank that was in it.
The tanks are a lot thicker than they look. I tried the slide hammer to pull the dents, not happening!. I have another tool to try. I may put a 240z tank in it, since I don't need any of the EFI ports, baffles or sizing.
What is the stock feed supply size?? this tank has a 1/2" feed port...
Stripped with some airplane stripper
  • Who's Online   0 Members, 0 Anonymous, 805 Guests (See full list)
