1971 HLS30-14938 "Lily" build
Patcon
So earlier there was a question about the crenelated rubber washers for the moustache bar. Anyone have any input into this?
Anybody have an idea where the solid ones came from? Some different application?
On ‎2‎/‎4‎/‎2018 at 8:17 PM, Patcon said:
Also I two different styles of mustache bar washers. Which is correct for a 240z? The upper ones with the crenelated rubbers on the bolts are the ones I suspect are correct. If so what are the other ones for?
The 1969 - 1972 TSB book shows crennulations in a drawing for a March 25, 1971 TSB, "Dampener Installation".  Carpartsmanual shows a few changes.  Assuming that #30 and #31 is the part.  The drawing looks screwed up, but the change dates match for the pair, and the label of "stopper" seems right.
http://www.carpartsmanual.com/datsun/Z-1969-1978/axle/rear-suspension
When I dismantled my 04/70 240z it had the crenulated rubber washers on it but I don't know if I was the first guy to remove the mustache bar.
Crenelated as in the style on the studs or the style on the string?
