1971 HLS30-14938 "Lily" build
Patcon
No insight from actually using them.  Are the pistons fully retracted?  The hydraulic pressure will be the same no matter how far the pistons are extended, or mismatched, so you could make them work by taking material from the pad surface.  One side's pistons will be more extended than the others, if I'm reading your problem right, but it won't affect performance.
The issue isn't pads. The  rotor hits the sides of the slots on the inside of the caliper, before it clears the strut ears
Here and here?  You're saying that if one fits the other doesn't?
I'd grind the inside interference before the outside mounting points.  If I had to use those.  But, were it mine, I'd just go back to the stock setup.
Yes the slot on the caliper hits the rotor before the caliper gets in position to bolt up. I thought about grinding but have ruled that out as too much of a hack and the fact the pads might not fit even if I get the rotor bolted up. I have considered going back to the factory caliper. I may still. I also thought about ordering what should be a plug and play caliper from Rockauto and see what I get...
  • 1 month later...
I still need to check on the front calipers and the front rotors
In the mean time I have been trying to get the rest of the suspension black so I can put it back down on some wheels
I painted the last control arm today and polished some spindle pins. I have found many times they will polish up nicely. I use lots of anti seize on reassembly
  • Who's Online   0 Members, 0 Anonymous, 769 Guests (See full list)
