1971 HLS30-14938 "Lily" build
Patcon
Does anyone have access to Nissan Fast? I wanted to get the part numbers for the clutches and plates that go in the 1988 300zx clutch LSDiff.
Does anyone know of an alternative to the Nissan parts? I know HybridZ had a group buy for plates a few years back
I found an online manual for the 88 300zx and it had the differential procedures for testing, break away torque and reconditioning
Seems like some of the hardbody differential parts might be interchangeable
https://www.nissanpartsdeal.com/parts-list/1995-nissan-hardbody_pickup_d21u/power_train/rear_final_drive.html?Diagram=380_A002
also this looked like an excellent source for internal parts
https://www.nengun.com/nismo/lsd-repair-parts
  • 1 year later...
624 days since a post!!!
Pffttt! Depressing...
Any way the car is still out of the shop and covered up and the Goon is occupying premium space but I did tinker a little today.
I pulled together about 20#'s of metal to go to the platers. It's an experiment. I did very little prep work other than degreasing. We'll see what I get back.
I also worked on one of the Cv axle halfshafts for the CLSD rear end. It's been sitting on my bench for almost 2 years. I found these numbers on the hub. Might be useful or cross-referenceable
  • 3 months later...
28 minutes ago, Patcon said:
So I got the plating back
I have the car back in the shop and the goons back outside.  I hope to have color on it this fall before it gets too cold
Just let me know if/when you need electrical help.
  • Thanks 1
So brought the car inside and cleaned it up. Used some Ospho on it. Then a couple of days later I sanded it all with 320 on a DA.20211030_182319_resized.jpg20211106_131034.jpg20211106_131040.jpg20211106_131047.jpg20211106_131054.jpg20211106_131102.jpg
So I realized that I might get some over spray on the headliner, which I installed while it was on the rotisserie. Then got it wrapped up
20211106_172805.jpg20211106_172819.jpg20211106_184218.jpg20211106_184227.jpg20211106_184237.jpg
So all wrapped up and was going to spray some epoxy but the idiot running the shop forgot to check if we had some!! :blush:
  • Haha 2
Wish I could sometimes! Me, myself and I are the only three working on this thing 😉
As a note, I jambed out the car with single stage but after ruminating on it for a while decided it would be easier to finish paint if I included portions of the hatch area and door jambs in my final paint. It makes it easier to tape up and not have a noticeable start / stop point
Can you share a pic or two of your paint setup? Shop air, dryers, etc?
I rigged up a transmission cooler on the fan of my compressor, it brings 300* air down to about 70* before entering tank. I want to believe that it reduces the amount of condensation in the tank, although I still drain some out of it.
Edited by DC871F
