Does anyone have access to Nissan Fast? I wanted to get the part numbers for the clutches and plates that go in the 1988 300zx clutch LSDiff.
Does anyone know of an alternative to the Nissan parts? I know HybridZ had a group buy for plates a few years back
I found an online manual for the 88 300zx and it had the differential procedures for testing, break away torque and reconditioning
  • 1 year later...
624 days since a post!!!
Pffttt! Depressing...
Any way the car is still out of the shop and covered up and the Goon is occupying premium space but I did tinker a little today.
I pulled together about 20#'s of metal to go to the platers. It's an experiment. I did very little prep work other than degreasing. We'll see what I get back.
I also worked on one of the Cv axle halfshafts for the CLSD rear end. It's been sitting on my bench for almost 2 years. I found these numbers on the hub. Might be useful or cross-referenceable
  • 3 months later...
So I got the plating back
I have the car back in the shop and the goons back outside.  I hope to have color on it this fall before it gets too cold
Just let me know if/when you need electrical help.
Blocking panels and wet sanding to 600 grit
I have a number of them ready for color. Most of them were pretty close to ready before I got pushed out of the shop by the Goon a while back. I may roll the chassis outside tomorrow and shoot some epoxy on it. We'll see
So brought the car inside and cleaned it up. Used some Ospho on it. Then a couple of days later I sanded it all with 320 on a DA.20211030_182319_resized.jpg20211106_131034.jpg20211106_131040.jpg20211106_131047.jpg20211106_131054.jpg20211106_131102.jpg
So I realized that I might get some over spray on the headliner, which I installed while it was on the rotisserie. Then got it wrapped up
20211106_172805.jpg20211106_172819.jpg20211106_184218.jpg20211106_184227.jpg20211106_184237.jpg
So all wrapped up and was going to spray some epoxy but the idiot running the shop forgot to check if we had some!! :blush:
Wish I could sometimes! Me, myself and I are the only three working on this thing 😉
As a note, I jambed out the car with single stage but after ruminating on it for a while decided it would be easier to finish paint if I included portions of the hatch area and door jambs in my final paint. It makes it easier to tape up and not have a noticeable start / stop point
Can you share a pic or two of your paint setup? Shop air, dryers, etc?
I rigged up a transmission cooler on the fan of my compressor, it brings 300* air down to about 70* before entering tank. I want to believe that it reduces the amount of condensation in the tank, although I still drain some out of it.
Edited by DC871F
