November 6, 20195 yr Author comment_586995 Does anyone have access to Nissan Fast? I wanted to get the part numbers for the clutches and plates that go in the 1988 300zx clutch LSDiff. Does anyone know of an alternative to the Nissan parts? I know HybridZ had a group buy for plates a few years back I found an online manual for the 88 300zx and it had the differential procedures for testing, break away torque and reconditioning Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=36#findComment-586995 Share on other sites More sharing options...
November 9, 20195 yr Author comment_587314 Seems like some of the hardbody differential parts might be interchangeable https://www.nissanpartsdeal.com/parts-list/1995-nissan-hardbody_pickup_d21u/power_train/rear_final_drive.html?Diagram=380_A002 also this looked like an excellent source for internal parts https://www.nengun.com/nismo/lsd-repair-parts Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=36#findComment-587314 Share on other sites More sharing options...
July 25, 20213 yr Author comment_625705 624 days since a post!!! Pffttt! Depressing... Any way the car is still out of the shop and covered up and the Goon is occupying premium space but I did tinker a little today. I pulled together about 20#'s of metal to go to the platers. It's an experiment. I did very little prep work other than degreasing. We'll see what I get back. I also worked on one of the Cv axle halfshafts for the CLSD rear end. It's been sitting on my bench for almost 2 years. I found these numbers on the hub. Might be useful or cross-referenceable Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=36#findComment-625705 Share on other sites More sharing options...
October 29, 20213 yr Author comment_630651 So I got the plating back I have the car back in the shop and the goons back outside. I hope to have color on it this fall before it gets too cold Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=36#findComment-630651 Share on other sites More sharing options...
October 29, 20213 yr comment_630652 28 minutes ago, Patcon said: So I got the plating back I have the car back in the shop and the goons back outside. I hope to have color on it this fall before it gets too cold Just let me know if/when you need electrical help. Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=36#findComment-630652 Share on other sites More sharing options...
October 29, 20213 yr Author comment_630653 I would love some when the time comes! Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=36#findComment-630653 Share on other sites More sharing options...
October 30, 20213 yr Author Popular Post comment_630719 Blocking panels and wet sanding to 600 grit I have a number of them ready for color. Most of them were pretty close to ready before I got pushed out of the shop by the Goon a while back. I may roll the chassis outside tomorrow and shoot some epoxy on it. We'll see Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=36#findComment-630719 Share on other sites More sharing options...
November 7, 20213 yr Author comment_631154 So brought the car inside and cleaned it up. Used some Ospho on it. Then a couple of days later I sanded it all with 320 on a DA. So I realized that I might get some over spray on the headliner, which I installed while it was on the rotisserie. Then got it wrapped up So all wrapped up and was going to spray some epoxy but the idiot running the shop forgot to check if we had some!! Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=36#findComment-631154 Share on other sites More sharing options...
November 8, 20213 yr comment_631166 5 hours ago, Patcon said: Fire him! Edited November 8, 20213 yr by DC871F Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=36#findComment-631166 Share on other sites More sharing options...
November 8, 20213 yr comment_631167 6 hours ago, DC871F said: Fire him! You can't fire the good ones. He'll learn and do even better. Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=36#findComment-631167 Share on other sites More sharing options...
November 8, 20213 yr Author comment_631168 Wish I could sometimes! Me, myself and I are the only three working on this thing 😉 As a note, I jambed out the car with single stage but after ruminating on it for a while decided it would be easier to finish paint if I included portions of the hatch area and door jambs in my final paint. It makes it easier to tape up and not have a noticeable start / stop point Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=36#findComment-631168 Share on other sites More sharing options...
November 8, 20213 yr comment_631178 3 hours ago, Patcon said: Wish I could sometimes! Me, myself and I are the only three working on this thing 😉 As a note, I jambed out the car with single stage but after ruminating on it for a while decided it would be easier to finish paint if I included portions of the hatch area and door jambs in my final paint. It makes it easier to tape up and not have a noticeable start / stop point Can you share a pic or two of your paint setup? Shop air, dryers, etc? I rigged up a transmission cooler on the fan of my compressor, it brings 300* air down to about 70* before entering tank. I want to believe that it reduces the amount of condensation in the tank, although I still drain some out of it. Edited November 8, 20213 yr by DC871F Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=36#findComment-631178 Share on other sites More sharing options...
