@DC871F
I have a 50 gallon Ingersol rand outside my shop. So cold air in the winter, not so much in the summer.
It comes through the wall and goes into about three loops of 3/4" copper line. Then it hits a pressure regulator and a water separator. The water trap has a drain plumbed through the wall that I can blow down
Then it travels across the shop about 30' and hits my three stage filter dryer. It's a nice unit with desiccant beads but it has gotten kind of pricey in the last few years. I only use this air source for painting and it stays shut off otherwise. When the beads turn pink, I bake them in the oven on about 200F until they're dark blue again
At some point I might rework the loop to be up near the ceiling and horizontal so the loops don't hold water that way. I could also do like you did and use a condenser as a cooler. Maybe, in my spare time 😉
Hope this helps
9 hours ago, DC871F said:
Can you share a pic or two of your paint setup? Shop air, dryers, etc?
I rigged up a transmission cooler on the fan of my compressor, it brings 300* air down to about 70* before entering tank. I want to believe that it reduces the amount of condensation in the tank, although I still drain some out of it.
Here's a good read on cooling the air with a 90s Honda condenser. Post #5.
2 hours ago, Patcon said:
@DC871F
Hope this helps
Thanks. Your setup is what I have been eye balling.
Do you ever get any moisture at all out of the dryer? They seem to work really well from all I have read and seen on youtube. I think the way you did it is better or at least the same from a refrigerated dryer, but I'm no expert.
I like the fan setup, thats probably 3 or 4 times the airflow I'm getting from the stock compressor fan. I do get water in the tank, but it never makes it to my air tools. When I start painting I'll probably redo my system to incorporate a higher volume fan.
2 hours ago, grannyknot said:
haha, and thus the thread on a new gun acquisition 😋
Yes, basically 😉
The gun I'm using has been used for all sorts of stuff. Its older and can be difficult to clean.
I thought I might get some better atomization and less overspray with a better gun. Since overspray is really just money floating down wind. I spent about $800 on paint last week. That was some basecoat, clear, some catalyst for a primer and a quart of epoxy primer. I'm using Nason paints, so a budget line of paints. Not top shelf. I already had sealer and high build primer. Things are drastically more expensive this year!
I got 4 coats of high build layed down.
It's always amazing how bad it looks after you shoot a mono color shiny coat on it. All of a sudden there's flaws everywhere! I will use a little spot glaze on the bigger flaws, and then I will start guide coating. It will probably need another round of high build after blocking it down.
So I am about to double check the tail light panel fitment but I keep breaking the retaining clips. So I had to buy some.
They look really good but they're not cheap!
You can see where the old one is cracked on top
I had one fail the other day and half of it went zinging across the shop.
I also started filling in the flaws on the rear the other day. It's gonna need some more high build...
Edited by Patcon
