1971 HLS30-14938 "Lily" build
Patcon
3 hours ago, grannyknot said:
Will you make the brace out of steel or having it machined out of aluminum?
Once I have a shape I will export a DXF file and have a piece of 3/8 steel plate torched out. Then weld it all up into a new transverse member
  • 4 months later...
On 6/26/2022 at 1:54 PM, Patcon said:
The car will be bright yellow when done
Yes offcourse!    (stupid me.. i was sleepy.. Lilly build...  what was i thinking.. :facepalm:   And the inside is already yellow.. 👍)
When do you think you spraypaint the rest? Next month?  Very good work so far!! 👍
