  • 1 month later...
So I did some rework on the car. The brown specks were pretty wide spread and very deep in the clear. I tried to sand them out but that made large dimples in the clear,
So I had to redo the job
You can see some of the dimpling in the glare of the light
I also didn't like the joints in the door jambs so I added some more seam sealer there.
Mask the joints off
Run some seam sealer with a caulk gun
Use a little lacquer thinner to smooth it down
Then I masked off the problem areas and shot some high build primer
Started blocking. You can still see the low spots
So I have starting looking for some exterior parts. Tail light strips seem to be available, but early car Quarter badges seem to be scarce. Also one listing I saw suggested they were handed. Is that correct? I need to look around and see if I have any here...
So I found a few badges...
2 of the "Datsun" emblems are metal one is plastic. One of the qtr panel emblems is pretty badly corroded. I do have a set of L&R, although I can't figure out why the early emblems are handed. The later emblems have slots for air towards the rear so that makes sense for handing. They really need rechroming.
Has any one found a vendor for restoring these emblems?
