1971 HLS30-14938 "Lily" build
Patcon
So I spent a little more time on the car today
I had this filler neck and it was stiff but not pliable. So I soaked it for about 36 hours. Made all the difference in the world. Really amazing...
Turns out it needs to be pretty pliable to get it installed
Who was looking for these?
Also I have this selection of gas pedals:
Which was is correct for my 71?
2 have plastic pivots and one has a metal pivot. The one with the metal pivot is also shaped a little differently
  • 1 month later...
So I started pulling the rear body harness in. There are two branches that go up. One for the dome light. One for the defroster.  The dome light is self explanatory, but how does the defroster route? All in the structure or only internal until its under the plastic?
6 hours ago, Patcon said:
Is dielectric grease the way to go
No.. dielectric grease is to keep water out of electric connectors.. it does NOT have conductivity.. it isolates!  Coppergrease does not but if it's the right stuff to use?  I would make the connection very clean and after connecting leave some coppergrease on it. (so not in between the connecting parts.) maybe google for some electric conducting stuff?
Maybe you could use some petroliumgelly like you do on battery poles to keep them from oxidating? (petroliumgelly does also not conduct electricity.. so not in between the connectors, on a battery pole it's different as the clamp wil make contact through the gelly as it's high clamping force.)
Hey, Charles, i just took a look at your picture on the frontpage of your topic and i thought it would be nice when you have your project finished to take a pic like that and put it at the end of this story accompanied with the first pic!  We might get to see some gray hairs? :ph34r:  (or even yellow hair from the paintbooth! 😁    )
  • Haha 2
Petroleum jelly in my opinion only makes it worse, wd40 works better then
  • Who's Online   2 Members, 0 Anonymous, 902 Guests (See full list)
