16 minutes ago, Patcon said:
Yeah, that would be a nice picture to end with. Definitely getting gray. Might get my kids in that one too. They've changed a lot too
I was shocked to see the more recent photos of Cody. I hadn't seen him since 2018.
11 hours ago, Patcon said:
So I started pulling the rear body harness in. There are two branches that go up. One for the dome light. One for the defroster.  The dome light is self explanatory, but how does the defroster route? All in the structure or only internal until its under the plastic?
Here are some pics that might help that I took as I was disassembling my 7/70. Basically as you described. HTH Mike
On 2/25/2023 at 2:53 PM, Patcon said:
Also I have this selection of gas pedals:
Which was is correct for my 71?
2 have plastic pivots and one has a metal pivot. The one with the metal pivot is also shaped a little differently
My 7/70 has the plastic pivot bracket.
Edited by CanTechZ
