November 20, 20231 yr Author Popular Post comment_659623 So I worked on the glass trim for the rear hatch glass some I have a nice 2 speed buffer but I don't like polishing these parts that way. If it grabs it they usually get destroyed and they're a little too much like blades to have whipping around you. So I used a buffing pad on a 2" Rolok This is what the finish looked like to start with I'm using white rouge This is after. You can still see some scratching but they will do for now. If I let myself be OCD, I could wet sand starting with 1500 probably and then buff but I don't want to slow my progress down right now  On another note, I soaked the blistered yellow zinc in citric acid for a day or too. When they came out they were black. But come to find out that just rinsed right off with water and a toothbrush. Then dried them off. I will bead blast them again before I replate Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=66#findComment-659623 Share on other sites More sharing options...
November 20, 20231 yr comment_659629 I had the same thoughts when i needed to do my 280zx chrome strips.. (I'm not gonna polish them on a bench polisher.. i already saw the parts fly around in my mind) You could "glue them temporary to a piece of wood with some (small "blobs") silicone, wait a day or 3 and polish the hell out of them.. then take a wire and get them off the wood and clean out the silicone on a clean towel. Edited December 4, 20231 yr by dutchzcarguy Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=66#findComment-659629 Share on other sites More sharing options...
November 20, 20231 yr comment_659635 Nice job on the hatch trim! I went thru all of this years ago with all of the windshield and hatch trim, drip rails, door glass frames, and the quarter glass frames. In the absence of air tools I used an old high speed drill motor, 4" buffing wheel and jeweler's rouge. I ended up holding each piece flat on the bench with one hand and polishing with the other. Not always the easiest to handle but at least I didn't have parts flying around the garage. I also polished the aluminum door sill plates. I used small screws in the existing holes to fasten them to the front edge of the bench to hold securely in place. Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=66#findComment-659635 Share on other sites More sharing options...
November 20, 20231 yr comment_659642 23 hours ago, Patcon said: So I worked on the glass trim for the rear hatch glass some I have a nice 2 speed buffer but I don't like polishing these parts that way. If it grabs it they usually get destroyed and they're a little too much like blades to have whipping around Hey, I like the Rolok idea, the last time I tried buffing SS window trim on a bench buffer I almost cut my face off. Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=66#findComment-659642 Share on other sites More sharing options...
November 21, 20231 yr Author comment_659650 3 hours ago, grannyknot said: Hey, I like the Rolok idea, the last time I tried buffing SS window trim on a bench buffer I almost cut my face off. I have had the buffer take trim pieces from me. It happens really fast even on low at 1800 rpm! It would be really easy to get hurt that way and it almost always damages or destroys the trim piece. This method seems much more controllable. I did polish the qtr glass frames on the buffer, but they are much sturdier Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=66#findComment-659650 Share on other sites More sharing options...
November 22, 20231 yr Author comment_659698 Here are the buffs I bought https://www.amazon.com/gp/product/B087R5HSNB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=66#findComment-659698 Share on other sites More sharing options...
November 22, 20231 yr comment_659701 Nice. Thanks for sharing. I've started thinking about buffing stainless items, as my project is getting to the stage where they will need to go back on the car. Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=66#findComment-659701 Share on other sites More sharing options...
November 23, 20231 yr Author comment_659702 1 hour ago, inline6 said: Nice. Thanks for sharing. I've started thinking about buffing stainless items, as my project is getting to the stage where they will need to go back on the car. I think in your case, you will probably want to wet sand before buffing unless your trim is scratch free. You are working towards a much higher standard than I am Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=66#findComment-659702 Share on other sites More sharing options...
November 23, 20231 yr comment_659706 Thanks, just ordered a pack of 20. Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=66#findComment-659706 Share on other sites More sharing options...
December 3, 20231 yr Author comment_659918 So I worked on jute some more the car. I ordered the jute from "The Roadster Factory" per @Zup. It was not quite enough to do the whole car. I am short one section for under a front floor mats. I also cut and buffed the hatch. That was a disappointing because I believe I have sanding scratches in the base coat. No getting them out now... 😞  Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=66#findComment-659918 Share on other sites More sharing options...
December 4, 20231 yr Author comment_659919 I worked on the hatch glass one day last week. I needed to get the trim into the gasket. I started with the top piece and then did the two lower corners. On the top piece I put the inner edge into the gasket and then used my thumb to roll the outside flap out and over the trim. Working my way down the piece. On the two lower pieces, I go them set in the corner so that both legs would go into the inner lip. Then I got one end tucked about 4", then I went to the other end and worked my way towards the corner. The issue gets to be where the trim has a much sharper corner than the gasket wants to make. Have to keep working and trying to shape the gasket to the tighter radius. I did eventually get it. I am hoping the hatch itself will help to reinforce the tight radius   Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=66#findComment-659919 Share on other sites More sharing options...
December 4, 20231 yr Author comment_659920 I have some questions about the hatch assembly. I had thought about installing the glass in the hatch before putting it on the car, but now I'm thinking it might be easier to get the hatch on the car without the extra weight of the glass. That would mean installing the glass from inside the hatch space though Also how do these mount? I may have answered my own question but wanted to be sure. I have new clips for these This is an old clip and it appears that there is emblem retainer that helps hold the clips to the car? I looked on car part manual and they say there are M4 screws holding the vents onto the hatch, but that doesn't seem right... https://www.carpartsmanual.com/datsun/Z-1969-1978/body-240z/tail-gate-panel-trim-lock-rear-bumper Edited December 4, 20231 yr by Patcon Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=66#findComment-659920 Share on other sites More sharing options...
