1971 HLS30-14938 "Lily" build
Patcon
I was looking for the radio antennae cable today. The one that runs down the left side of the car.
I found these. I think they are for the S30. They are 12'4" OA
Which end of the cable to which end of the car?
On 1/10/2024 at 8:34 PM, Patcon said:
So I had a great visit with Steve Nixon today of 240zrubberparts.com. It was a great time and I got to see the progress of his car. He is so close to having a running car.
If you ever need parts from Steve just give him a shout. Many orders he makes when ordered. The only things that show in stock are the extras from previous orders.
Getting your hands on those is super exciting.  I have placed several orders for Steve's products.  I am thrilled that he is a reliable resource for these otherwise unobtainable parts.
Edited by inline6
@SteveJ
I was Ohming out the radio antennae cables today. They have some areas that seem damaged and I wanted to make sure they were ok. The outside of the jacket rings out but the center conductor of the antennae cable shows as OL. I tested two different cables the same way and both did the same thing. Should the center core show continuity?
I worked on getting the windshield ready for installation today. Super frustrating! I damaged the weatherstrip trying to get the trim into it. :angry:
I worked this drivers side lower trim in from the outside in. That puts a lot of pressure on the seal when you get to the corner.
The pic I was using tore the seal because of that pressure
I would expect the center post would have continuity through the cable, but I could be wrong.
You could always set up a test rig to test it out or just buy a new cable and run it through the car. You can get a 20 foot or 15 foot cable on Amazon.
  • Thanks 1
So I switched gears, patience was gone on that one
So I started putting freshly plated headlights back together with Steve Nixon's parts
Then I hit a snag. The buckets are different. I was trying to figure out how the headlight seals from precision went on. Then I realized that one set of buckets didn't have the 4 little holes like the one at my thumb. The seals have for posts that pull through these holes
So I had to reselect my buckets so I had 2 that both had the 4 little post holes
Then I tried to figure out a way to feed the wires through the new wire jacket I got from Steve. I took the terminals out of this plug but even staggering them they weren't going to go through the jacket.
So I tried to uncrimp this one but that wasn't happening and then I remembered that I had some new Vintage connections terminals. So I cut them off
I still couldn't get them to feed through the jacket. So I had to feed a different single wire through the jacket from the other end and use it as a pull wire to pull the wires back into the jacket
I got one bucket all the way redone!
I love clean new parts!!!
  • Like 4
