February 18Feb 18 Author comment_674629 9 hours ago, inline6 said: I think I'd recommend seeing if you can find some better escutcheons (inner door handle trim), Charles. I don't recall seeing many as rusty as those. So, I think you will have a good chance at finding some nicer ones to either use as is after a bit of polishing, or as better restoration candidates. I agree the inside of the cups are pretty crusty on some of those. But my thinking was only the perimeter shows after you put the plastic inner cup in. So only the edge of the cup needs to turn out nice... Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-674629 Share on other sites More sharing options...
February 18Feb 18 comment_674630 Let the chrome people know. You don't want to pay for their time to try to fix that rust area. Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-674630 Share on other sites More sharing options...
March 2Mar 2 Author comment_675023 Question: I ordered the S30 door weatherstrips. They should be here shortly. Do they get glued on or does the windlace hold it well enough? Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-675023 Share on other sites More sharing options...
March 2Mar 2 comment_675030 14 hours ago, Patcon said: Question: I ordered the S30 door weatherstrips. They should be here shortly. Do they get glued on or does the windlace hold it well enough? There is a great installation video on the S30world website. They don't use any weather strip glue. He does show using super glue for the butt joint at the middle of the lower section. Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-675030 Share on other sites More sharing options...
