February 18Feb 18 Author comment_674629 9 hours ago, inline6 said: I think I'd recommend seeing if you can find some better escutcheons (inner door handle trim), Charles. I don't recall seeing many as rusty as those. So, I think you will have a good chance at finding some nicer ones to either use as is after a bit of polishing, or as better restoration candidates. I agree the inside of the cups are pretty crusty on some of those. But my thinking was only the perimeter shows after you put the plastic inner cup in. So only the edge of the cup needs to turn out nice... Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-674629 Share on other sites More sharing options...
February 18Feb 18 comment_674630 Let the chrome people know. You don't want to pay for their time to try to fix that rust area. Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-674630 Share on other sites More sharing options...
March 2Mar 2 Author comment_675023 Question: I ordered the S30 door weatherstrips. They should be here shortly. Do they get glued on or does the windlace hold it well enough? Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-675023 Share on other sites More sharing options...
March 2Mar 2 comment_675030 14 hours ago, Patcon said: Question: I ordered the S30 door weatherstrips. They should be here shortly. Do they get glued on or does the windlace hold it well enough? There is a great installation video on the S30world website. They don't use any weather strip glue. He does show using super glue for the butt joint at the middle of the lower section. Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-675030 Share on other sites More sharing options...
March 25Mar 25 Author comment_675426 So a quick update...I finally got the doors seals last week. They have to be signed for and nobody was ever around and I was having a hard time getting a re-delivery lined up.Anyway, I got them and put them on last Saturday. They are really nice!!!I had the precision seals and you really have to slam the doors. The new seals are nice and very soft. The door closes really nicely now. You do have to be careful when tucking the seal into the windlace that you use a dull enough tool as they will rip if you're not careful. Also one of my upper corners is coming apart but I will reglue it. It is much easier to do if you have some help. The seal wants to come back out of the windlace if you don't have someone there to hold it for you.Overall, really pleased and well worth the money! Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-675426 Share on other sites More sharing options...
March 26Mar 26 comment_675427 This is the first I've heard of these "s30world" door seals. I too have the Precision one's now. Looks like this is the way to go! Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-675427 Share on other sites More sharing options...
Sunday at 03:32 AM4 days Author Popular Post comment_675453 Got tires this week Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-675453 Share on other sites More sharing options...
Sunday at 03:39 AM4 days comment_675454 Sweet! Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-675454 Share on other sites More sharing options...
Sunday at 02:40 PM4 days Author comment_675456 I have two problems I need help with:The first is a leaking speedo cable. When I filled the transmission it took more than a quart and a half to overflow the fill plug hole. The speedo cable was leaking a few weeks ago right at the large cable nut. So I wrapped the junction with Teflon tape. That worked for a while but now I believe it is leaking out my heat shrink seals at the end of the cable. One concern I have is not having the oil travel up the cable and leak out from under the dash like somebody was posting about in the past. I don't recall how that got resolved. Any suggestions for dealing with this leak?The second issue, is where to source the little plastic pieces that lock the various bars into the door lock mechanisms? Edited Sunday at 05:00 PM4 days by Patcon Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-675456 Share on other sites More sharing options...
Sunday at 02:42 PM4 days Author comment_675457 Ok, I solved the second onehttps://www.amazon.com/OAUTOO-165pcs-Assortment-Chrysler-Toyota/dp/B0C5VB83XN/ref=asc_df_B0C5VB83XN?mcid=52195ebd89f3349f9f7232da7174862d&hvocijid=13820313418102357919-B0C5VB83XN-&hvexpln=73&tag=hyprod-20&linkCode=df0&hvadid=721245378154&hvpos=&hvnetw=g&hvrand=13820313418102357919&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9010452&hvtargid=pla-2281435179258&psc=1Any ideas on the first problem?? Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-675457 Share on other sites More sharing options...
Sunday at 04:15 PM4 days comment_675458 Maybe this seal?https://www.thezstore.com/product/3008/factory-speedometer-pinion-o-ring-small-70-86-240z-260z-280z-280zx-300zxThere is also an O ring that I think goes in the cable end. IIRC Edited Sunday at 04:16 PM4 days by emccallum Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-675458 Share on other sites More sharing options...
Sunday at 06:39 PM3 days comment_675459 The one above goes down inside the speedo cog housing, the O-ring goes on the outside where it slides up into the transmission from what I remember.espirist shows it here:I found a picture of the O-ring I'm thinking about.Uploading Attachment... Edited Sunday at 06:43 PM3 days by siteunseen Link to comment https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=102#findComment-675459 Share on other sites More sharing options...
