Ok, I need some HELP now.
I have most of the car roughed out, but I need to finish the rear valance. The car was rear ended at some point and the bumper damaged the rear valance. I worked on it a number of years ago but I don't like the finished results.
So I tried to start on the rear yesterday. I made a template of the rear curve of the hatch
When I compared it to the rear valance there is quite the difference. So then I figured I needed to have the correct bumper. I was able to finally order some out of Vietnam but I located a straight center section today, in the mean time.
Here is the way it currently sits
It is a little hard to tell but it's really wavy and uneven. I cut out the center of the valance and pulled the center section. Then I welded it back in. You can see one of the joints on the right
This is how the current bar fits
20181215_134221.jpg20181215_134234.jpg20181224_095643.jpg20181224_095709.jpg20181224_095714.jpg20181224_102455.jpg
Much closer on the ends than in the middle by about 3/8". I assume this gap is supposed to be consistent. Can someone confirm that for me? Also approximately what is this gap supposed to be?
At this point I am contemplating drilling out all the spot welds and removing the rear valance entirely so I can try to get it straight and right. I really need to be painted by February if I am going to have a shot at being ready for Zcon 2019. I hate to add the extra work but right now I don't see a good way around it
8 hours ago, Patcon said:
Here are some pictures of the air dam transition I don't like
I don't like the abrupt change where they meet
I would prefer to figure out a way to make it a little more subtle
Even more than he is holding right here
What's it look like with a thin bumper held up there?
Paint it a light silver.  That looks good against yellow in my o pin ion.
A better view of the current situation
130 spot welds later!!
I think you will be able see the damage inside the frame rail
Those wrinkles above the bumper mount shouldn't be there
The back of this should be flat too
There is a dip below the light in the first picture. I don't think that should be there. It is where the panel got forced under the interior floor panel
The second picture has a way area. I believe this is supposed to be flat. Can somebody post me a good picture of this panel so I can tell how it's supposed to be?
More damage on the left side of the license plate under the finishers
3 hours ago, grannyknot said:
I've always wanted to see inside that rear box section, it doesn't look too bad,  are you going to try and save the outer skin of the valance?
Yes, I have to reuse the valance, since I don't have a replacement and probably can't source a superior candidate. There are several areas of damage that I should be able to pull metal from toward the rear. I am surprised the box section isn't heavier metal, when it's all welded up it is very hard to pull with hand tools. I think there may be some extra metal in the floor too. I order two new frame clamps last night because I am not sure what I have will work. There is a wrinkle in the drivers quarter corner sub-frame that I am going to take a shot at. For a proper repair, the quarter would have to come off and that's not happening! I a made a raggedy mess out of the valance because my previous repairs had large puddle welds so they took big holes to break free. I think I will weld new little patches into the valance after dolly work and then make new smaller holes for puddle welds.
