Posted May 5, 20169 yr comment_494315 Hey guys, New to the Forum, tried the search button but could not find the answer i am looking for, recently purchase 73 Z stock, i have 14' wheels at the moment and wanted to upgrade my brakes to either four piston caliper kit or the wilwood big brake kit. To my understanding i need to upgrade to bigger wheels 15 or higher. I found some wheels that are 16x8x0 offset. will these rims fit, would i need spacers and are to wide? any input is appreciated. thanks Link to comment https://www.classiczcars.com/forums/topic/55407-wheel-size/ Share on other sites More sharing options...
May 5, 20169 yr comment_494316 Yes, you'll need bigger wheels to fit the larger calipers. I just put a set of 16x7, zero offset Konig Rewind wheels on my '72 240z with 205/55R16 Cooper tires on it. Next to no rub and the combination looks real good (in my opinion). I ordered them from DiscountTireDirect.com and due to a system glitch got a super deal for around $600 that they decided to honor. They fit a lot better than my Xterra 32's that I put next to the car for comparison with the original 14" steelies. Link to comment https://www.classiczcars.com/forums/topic/55407-wheel-size/#findComment-494316 Share on other sites More sharing options...
May 5, 20169 yr Author comment_494318 thanks for posting, the wheels im getting should not be problem then since its only 1' wider than yours Link to comment https://www.classiczcars.com/forums/topic/55407-wheel-size/#findComment-494318 Share on other sites More sharing options...
May 5, 20169 yr comment_494320 Really depends on how wide of tire you put on, and its the front that will rub when you turn. I wanted to go 225, but I'm not ready to replace my front valance (yet). Link to comment https://www.classiczcars.com/forums/topic/55407-wheel-size/#findComment-494320 Share on other sites More sharing options...
