1976 280Z.  Car was given to us.  Engine just rebuilt and put back in.  Getting spark.  Fuel pump replaced with known good unit (parts car that ran).
Dropping resistors measure 6 ohms per troubleshooting guide.
Relays replaced
#2 injector does not measure 12V at ECU (all others do)
brand new fuel filter
i have pressure at the rail (loosen hose clamp and fuel sprays out).
spark plugs are not wet when removed.
i suspect that the injectors are not opening
timing could be off as I did the rebuild myself :)
brand new battery.
car turns over, does not start.
any ideas?
https://www.classiczcars.com/forums/topic/55469-wont-start/
The ECU opens the injectors based on what it sees on the blue wire from the coil negative to the ECU Pin #1.  You can test that circuit by connecting a wire to coil negative and tapping it to ground with the key On.  Every tap should cause a spark from the coil and every third tap will case the injectors to click.
You can also test continuity to coil negative from Pin 1 before getting crazy with jumper wires.
Double checked all EFI connections - appear connected.
Tried starting fluid after the AFM, no luck.
Since I have a parts car (that ran), I will try ECU swap next.
Next I'll check the clicking of the injectors - need my son there to turn the key.
Thanks for the help.
One of the simplest things that you can do is to check continuity between the coil's negative terminal and Pin 1 of the ECU connection.  You'll have the connector sitting in front of you before you can even take the ECU out.
But not starting with starting fluid is a significant sign that you're not getting proper spark.  Starting fluid (the real stuff, not WD-40 or brake fluid) is very flammable.  If the engine won't at least pop a few times then it's not getting to where the spark is, or there's no spark under cylinder pressure. I wouldn't do any fuel related stuff until I got a few pops with starting fluid.  Remove one of the hose to the intake manifold and squirt fluid directly into the manifold.  Ignition is a completely separate thing from fuel.
Also, you're not really "showing your work" (like math class).  You said "appears connected" which could mean that you just eyeballed a few things.  That's not good enough.  C-:confused:.
Edited by Zed Head
some of the clips on the fuel injectors were missing and I replaced those and insured they were snapped in place.  I did touch each one of the connectors to verify connection.
I did use real starting fluid also.  will go into the manifold directly.  I did get one pop, but that was it.
I haven't run a continuity check from the coil's negative wire to the ECU bc I thought I had to actually run a wire with an alligator clip to the inside of the car to get close enough to pin 1.
With the key off, you can connect a jumper wire from the coil negative to ground,  Then check Pin 1's continuity to ground.  If Pin 1 shows continuity, then there's a complete circuit.
Or, you can just check for voltage at Pin 1 with the key On.  Power will pass from the battery through the coil to the negative terminal and down the circuit to Pin 1.
Use the Fuel Injection Guide to make sure you're measuring Pin 1.
Edited by Zed Head
Changed download to classiczcars.com
If you are not getting any response from starter fluid, you must have a problem with spark or it's flooded and the spark plugs are so wet they wont spark.
How did you check spark? Your saying "Getting spark", but not explaining how you came to that conclusion. Explaining what you did step by step can give clues for others to give you better help and advice.
You could have a bad connection or bad TIU. I would concentrate on that first. You should get some sort of response from starter fluid. You think the injectors are not opening which could also indicate no signal from pin 1, coil trigger.
