ignition switch
So, while re-wiring my 72, i found that both the ignition switch and the lock cylinder are bad. After looking at all the vendors and ebay it seems they all sell the same chinese re-pops. The lock cylinders dont have the correct keys. But, alas, there is hope!!! :D
Standard part # US-169L and US120, and both are available. I should have them tomorrow from my local parts store and i will update in my rebuild thread.
amazon has them both here
http://www.amazon.com/gp/search/ref=sx_as?keywords=ignition+switch&rh=n%3A15684181%2Ck%3Aignition+switch&qid=1463494332&vehicle=1972-67-2284-20-----14492------1-1
Well, the Ignition switch is one of those that you can't take apart, clean up and reassemble. So it is hit or miss if they will work or not.
To each their own on new or used I suppose.
In opposition to Capitan Obvious, My 45 year old Ignition switch works just fine.
Not all of them will end up like the one above. perhaps there was another issue with the starter and/or solenoid / wiring / misuse that caused this?
Not trying to plug my part for sale, I really don't care about that.
I am with Patcon and would prefer a used original over a Chinese replacement. They can't all be burnt, Just saying.
Standard motor parts are decent, I have bought some in the past. They used to have a top quality line for some items that were supposed to be a better quality than their standard pieces. Not all parts were offered in the duel lines.
As you probably know the part shown above wont help with the keys pulling out, just the electrical contacts. US-120
Standard does offer the tumbler with keys too. US-169L
The Standard parts also come with a 3 yr / 36K warranty too, can't go wrong with that. :)
Hope it all works out good for you Sweaty.
