hr369 Posted May 27, 2016 Share #1 Posted May 27, 2016 Would you accept this zinc chromate plating? Maybe i m\isunderstood what this service is. Are you just paying for the plating or plating + metal finishing? I had these professionally plated and they came back looking like this. As you can see there are very obvious grinder marks that show thru. At the very least a DA sander would have improved the look of this. Link to comment Share on other sites More sharing options...
Patcon Posted May 27, 2016 Share #2 Posted May 27, 2016 Did those come from Norm? Link to comment Share on other sites More sharing options...
beermanpete Posted May 27, 2016 Share #3 Posted May 27, 2016 Finish coatings are thin and generally will not hide surface flaws such as scratches and pits. Most finishing shops don't perform any polishing prior to the finishing you ask for. My experience with finishing is: You get out what you put in. Link to comment Share on other sites More sharing options...
Zed Head Posted May 27, 2016 Share #4 Posted May 27, 2016 A plating shop would probably just do a degrease then a plating dip. Electroplating is all about filling cracks and crevices for corrosion resistance, usually. You'd have to see the service description to know what they were offering. Link to comment Share on other sites More sharing options...
nix240z Posted May 27, 2016 Share #5 Posted May 27, 2016 The plating finish looks really good, the problem is someone took some sort of grinding tool to it. The plater can only plate what is given to him. If it was me I would have sanded down the area and then polished it out the best I could to get rid if the grind marks before I would have sent it to the plater. Even after the sanding and polishing you would still see the scuff marks after plating. Link to comment Share on other sites More sharing options...
hr369 Posted May 27, 2016 Author Share #6 Posted May 27, 2016 4 hours ago, nix240z said: The plating finish looks really good, the problem is someone took some sort of grinding tool to it. The plater can only plate what is given to him. If it was me I would have sanded down the area and then polished it out the best I could to get rid if the grind marks before I would have sent it to the plater. Even after the sanding and polishing you would still see the scuff marks after plating. Those grinder marks were done by the plater not me Link to comment Share on other sites More sharing options...
siteunseen Posted May 27, 2016 Share #7 Posted May 27, 2016 1 hour ago, hr369 said: Those grinder marks were done by the plater not me Not acceptable. Link to comment Share on other sites More sharing options...
Patcon Posted May 28, 2016 Share #8 Posted May 28, 2016 Were there stickers on the cases where the grinder marks are? Link to comment Share on other sites More sharing options...
hr369 Posted May 28, 2016 Author Share #9 Posted May 28, 2016 one had a sticker, the others had a little corrosion in those areas Link to comment Share on other sites More sharing options...
hr369 Posted June 1, 2016 Author Share #10 Posted June 1, 2016 (edited) On 5/26/2016 at 5:00 PM, beermanpete said: Finish coatings are thin and generally will not hide surface flaws such as scratches and pits. Most finishing shops don't perform any polishing prior to the finishing you ask for. My experience with finishing is: You get out what you put in. I printed up some stickers and it covers some of the grinder marks. Going to be buying my own plating kit so I have more control over the process. Edited June 1, 2016 by hr369 Link to comment Share on other sites More sharing options...
bartsscooterservice Posted June 1, 2016 Share #11 Posted June 1, 2016 Not good. Go back. It was done to quickly, and the preparation wasn't done right. That grinder marks should have been sandblasted. The yellow is only touching the edges as you can see. Link to comment Share on other sites More sharing options...
hr369 Posted June 12, 2016 Author Share #12 Posted June 12, 2016 (edited) Well here is the finished radio. Except for the 2 bottom pieces it turned out pretty good. Still can't replicate the nice plastic chrome that the factory did. I used model paint called chrome silver and covered it with a clear coat. It's passable. Anyone have better results with chrome paint? Plastic connectors I got online at vintageconnections.com Edited June 12, 2016 by hr369 Link to comment Share on other sites More sharing options...
