Recently Browsing 0
1976 280z, stock system.
Had some bogging at around 3000 rpm, adjusted the TVS. Checked plugs (which are new, only been run when test firing engine).
I assume the best option will be to "GET A NEW INJECTOR", but I'm trying to avoid that right now... (I know I might have to eventually....)
All the plugs looked the same except one, Cylinder #5 was brand new looking. Could be no spark, no fuel, or possibly being "steam cleaned" from a water (head gasket) leak.
Checked spark, swapped plugs, wires, etc... SPARK IS GOOD TO ALL CYLINDERS. Tested in multiple ways.
Did the screwdriver test. Verified all the other injectors have good "tapping" noise, the "bad" one was muffled or no "tap"....
Pulled the fuel rail, disconnected coil, turned engine over with rail connected with longer hose and set to spray on cardboard. Confirmed that #5 fuel injector not spraying. The others were.
Took bad injector off, and used the 9v method to get it opening/spraying off the car with spare injector connector. i did this to my "spare" used injectors too. Off the car, they all clicked and were not clogged.
Measured resistance on the "bad" injector and the known good ones, about 3 ohms for all. I've read most injectors should be 10-14 ohms, but maybe these are low impedance ones? Either way, the ones that were working and the "bad" ones had the same resistance values.
Anyways, still no fuel from the bad injector. Swapped injector connectors to make sure it wasn't them. Same result. So I know the connectors are good.
I then swapped the #5 and #6 injector on the rail. Same issue, the "bad" injector (now in cylinder 6 position) wasn't spraying, the others were. So this pinpointed the problem to the injector itself (not the fuel rail, not the electrical connections)
Manually pressed the "pintle" on the bad injector with a dentist-type tool. Voila, a nicely patterned fuel spray came out!
Cranked again, no spray from this injector, others are good.
So I know this "bad" injector is not clogged, had same resistance as the other injectors, can spray, and has good power supply/input. (as verified by switching connectors and position). (I also moved the clean spark plug to #6 so I can monitor it).
The other "spare" injectors I have seem to do the same thing (I thought it was odd that not 1 of the 4 spares were good, but will spray manually???)
What voltage does the injector get from the ECU? I know they always have 12v, but the "pulse" is less? I can get them to operate fine off of the car with 9 volts. Maybe less voltage isn't enough? But then why the same resistance as the others? (V=IR)
What am I missing? Or is it possible this/these injectors are still dead, despite the successful tests?
Thanks
https://www.classiczcars.com/forums/topic/55551-one-bad-fuel-injector/Share on other sites
