Check engine light does not flash when turn on.
OBD 1 reader failed.
Light bulb is good.
ECU is good.
Any ideas?
Also I attached a Pix, Where does this plug connected? Is part of the Obd 1 connector?
A 300ZX forum might be able to provide more information. Have you looked at http://www.xenonzcar.com to see if the FSM is available to get diagnostic info?
