1978 280z Radio
gotham22
Hello everyone, I just bought a 1978 280z and love it!!!!  Its my first datsun!  I have what I believe to be the original radio.  The am works fine but the FM is just static.  Anyone seen this issue before?  Is it fixable?
Thanks
  • 4 months later...
In case anyone else has this issue I wanted to provide some more info.  I sent the radio off to a repair shop who said the FM was shot and that it could not be fixed.  So I started looking for another radio.  The radio that came with the car was a Hitachi KMZ-2411z.  I could not find another one for less than $1k.  Looking through Ebay I found a Hitachi 2501BA for a datsun 810.  Turns out that although the model numbers are different this worked perfectly in my car.  Did not need to change a thing.  Also, it has a 5pin din connector at the back. I used this to plug in my iphone.  Works great!
Probably a cold solder joint somewhere on the circuit board and solder needs to be reflowed or a transistor is bad.
You can try taking the cover off the radio then poke and prod the circuit board while it's powered up to see if FM comes back.
