Alternator not powering battery
jlenownnab
Hello, I have searched previous threads and am not coming up with an answer. I have no power at the signal wire from the voltage regulator to the altenator. I have replaced the altenator, then the battery, then I thought maybe I got a bad altenator and replaced it again after getting it bench tested, then the voltage regulator in that order. Any ideas?? Thank you in advance.
Edited by jlenownnab
there are a couple wires not hooked up to anything
What year is your car?
I think that you might have an internally regulated alternator.  That's what your picture looks like.  Your mechanic probably thought it was a direct swap, and probably meant Sense, not Signal.  If he did install an internally regulated alternator (1978 - 1983 Z and ZX) then he has to do some wiring or buy the adapter below.  It's not a bolt-on swap.  I'd buy the adapter, it's a plug-in and contains the diode to keep the engine from running when the key is turned off.
Here a link-  http://www.thezstore.com/page/TZS/PROD/12-4067
I have a 75, he said I should consider putting a internally reg alt in but I like to keep things original. I asked orielys for a alternator for a  my tachometer isn't working either, not sure if that is related? he prob meant sense, he said he has to get back to old school thinking. there is a "t" shaped plug, I don't remember seeing a screw down terminal on bat. where is that coming from? thanks.
Check for F and N molded in to the back of the alternator by the T plug (the right circle in my picture).   Oreillys has been known to give the wrong parts.  If they gave you the wrong alternator it will have S and L molded in to the back.  You can also see BAT molded in where the charging wire goes (the left circle).
I think the external regulator systems might not get power to N until the key is on.
Your mechanic should know these things.  Is he a professional or just somebody you know?
