October 12, 20204 yr comment_607809 Cobra Kai gadget! Link to comment https://www.classiczcars.com/forums/topic/55728-float-sync/?&page=4#findComment-607809 Share on other sites More sharing options...
October 13, 20204 yr comment_607826 I purchased a set of these about 6 weeks ago, it took me 3 tries to set the floats correctly . the car never ran so good, as he states in the instructions to measure up 9/16" and that is the correct setting. my floats were 7/16" up and always had hard starting when it sat for a while, the car runs perfect now. I did the mm measurement also and it was a pita to do blowing in the fuel line while lifting up the float and taking a measurement. it was never right no matter how much I kept playing with the floats . this tool is a must!!!!!!!!!!!!!!!!!! great job randy Edited October 13, 20204 yr by kully 560 Link to comment https://www.classiczcars.com/forums/topic/55728-float-sync/?&page=4#findComment-607826 Share on other sites More sharing options...
April 20, 20222 yr comment_639526 Are you still selling the Float sync tool? I cant find it on ebay. I saw your video an think this may be my problem, I would like to test it. Thank you Link to comment https://www.classiczcars.com/forums/topic/55728-float-sync/?&page=4#findComment-639526 Share on other sites More sharing options...
April 20, 20222 yr Author comment_639539 I don't currently have any units left for sale but am considering producing more if there seems to be sufficient interest. Link to comment https://www.classiczcars.com/forums/topic/55728-float-sync/?&page=4#findComment-639539 Share on other sites More sharing options...
April 20, 20222 yr comment_639544 4 hours ago, vspot11 said: Are you still selling the Float sync tool? I cant find it on ebay. I saw your video an think this may be my problem, I would like to test it. Thank you Have you opened the float bowls lid to see if you have fuel in the bowls? Do you think your floats are too high or too low? Link to comment https://www.classiczcars.com/forums/topic/55728-float-sync/?&page=4#findComment-639544 Share on other sites More sharing options...
April 20, 20222 yr comment_639553 I figured out a quick fuel bowl test not long ago. Common sense but I'm a little slow. IF you can find a clear straw that will fit down inside the overflow bung on top you can stick it down and put your finger on the top end holding the level in place. Compare the fuel in the straw from the bottom to the top of the rectangular boss on the float bowl to see how close you are. I used a straw off a can of Quick Stuff foam insulation BTW. It's thicker plastic than a coffee straw. Look at this picture to see where the fuel should be. Hope it helps. It's a quick way just to get an idea. There's a lot more precise ways and I personally use this method with the clear hose for a better "quick and dirty" carb adjustment. Link to comment https://www.classiczcars.com/forums/topic/55728-float-sync/?&page=4#findComment-639553 Share on other sites More sharing options...
April 20, 20222 yr comment_639557 I have completely going through the carbs and cleaned and replaced multiple things on recommendation of z therapy. I have a 280 that was carbed and it runs rich like can't sit in the garage for more than 10 min without hurting your eyes. I replaced the fuel system, just turned the fuel reg down to 1 and did not change it. I am going to try the idea you have in the picture, that should work. Thank you for the response. Link to comment https://www.classiczcars.com/forums/topic/55728-float-sync/?&page=4#findComment-639557 Share on other sites More sharing options...
April 20, 20222 yr comment_639558 You'd be better off using clear hose. That Great Stuff straw was a bitch wiggle and twisting around the float. I think the gas softened it up after a bit. Link to comment https://www.classiczcars.com/forums/topic/55728-float-sync/?&page=4#findComment-639558 Share on other sites More sharing options...
April 20, 20222 yr comment_639559 This is how I figured mine out. It's easy once you wrap your head around the basic functions. Good luck! Link to comment https://www.classiczcars.com/forums/topic/55728-float-sync/?&page=4#findComment-639559 Share on other sites More sharing options...
April 22, 20222 yr comment_639587 On 4/20/2022 at 6:57 PM, vspot11 said: I replaced the fuel system, just turned the fuel reg down to 1 and did not change it. Please elaborate. Fuel regulator? Setting 1?? Link to comment https://www.classiczcars.com/forums/topic/55728-float-sync/?&page=4#findComment-639587 Share on other sites More sharing options...
April 22, 20222 yr comment_639588 It sounds like the fuel regulator my dealership used back in 1974. When the dealership did the electric pump on my 73 they put a round adjustable, shinney silver fuel regulator between the Engine bay fuel filter and the mech fuel pump which they left in the circuit. The regulator was maybe 2.5 - 3 inches with a dial on the top with labeled detent stops labeled something like 1 through 6. Link to comment https://www.classiczcars.com/forums/topic/55728-float-sync/?&page=4#findComment-639588 Share on other sites More sharing options...
April 22, 20222 yr comment_639592 Yes a fuel regulator, I had it at 3psi and turned it down to 1 psi. I replaced the old one with an aero regulator. It still did not reduce the richness of the engine. Link to comment https://www.classiczcars.com/forums/topic/55728-float-sync/?&page=4#findComment-639592 Share on other sites More sharing options...
