  On 7/31/2016 at 1:51 AM, Captain Obvious said:
Did SteveJ have oil of Aphrodite and the dust of the grand wazoo?
Yes, he did but fortunately we didn't have to use them because they're in limited supply!
If you like the picture, you'll love the video...the video of cleaning the turn signal switch. I have to do editing, but the cleaning work is done. Charles, Cody will be amazed at how well the switch operates. It is now as smooth as silk.
I didn't realize how much video I shot. It was about an hour or more. Right now it's being copied to the wife's computer because it's a lot newer than mine and runs better. I think it will take a while to edit the videos down to size.
Edited by SteveJ
  • 1 month later...
As long as you're going through the headlight system, be sure to clean the chassis grounds as well. They're notorious for causing a lot of goofy symptoms and problems and are often overlooked.
Edited by NVZEE
Thanks
One of the problems with the 510 for me is knowing where the ground all are. I know where they are on a Z but the 510 is a little different
