passenger side speaker 75 280z
Dave WM
I put 2 four inch Pyles from walmart behind the headrest on my '77. Fit perfect and cost $30 or something close plus the oe front speaker, sounds good sitting in the garage but fire it up with the header and 2.5" exhaust from msa and I just as well sing to myself, "hold me closer, Tony Danza" by Elton John. LOL
Questions:
am I missing a passenger side speaker connection on my 75 280z? I recall looking for bullet connectors when I last had the panel off (rear by tank filler).
If the harness did not come with a provision for a passenger side speaker, as standard I have to assume it was an option. If so can some confirm the factory location and lead dress and wire colors for the option.
Thanks
Dave
answering some of my own questions
the speaker for the driver side wraps around to the passenger side, terminates at a connecter under the passenger seat. The wiring diagram shows to unused sections of the body harness plug, opposite the W and WB for the driver side speaker. Seems like it would be easy enough to activate those for a X and XB wires for the new speaker passenger side, would still like to know the X color if anyone knows what that is.
the wiring diagram does NOT show provisions at the radio plug from the console harness for extra speaker wires to be added. Not to mention I don't even know if my car still has that plug since its an aftermarket radio, and some hack may have just cut it off.
So I may have to engineer an addition to the console harness back to the Plug under the passenger seat, as well as see what kind of radio plug I currently have if any.
Edited by Dave WM
  • 4 weeks later...
ok so the speakers I used for the install sound way too bass, like all the highs are gone. sounded fine until I put the trim panels back up, so I assume its just some acoustic anomaly that will need some better matched speakers for the OE install location. Next up I have some coax speakers on the way with a tweet to see if that helps. Plus I will reinstall the OE speaker for comparison. If anyone has an OE speaker that you like to sell let me know (in case they simply work better).
  • Who's Online   0 Members, 0 Anonymous, 557 Guests (See full list)
