Honda wiper upgrade
chiefmd
Just finished the wiper upgrade. It functions and parks as it should with this exception. Wiper at the bottom of the windshield I turn them on, the wipers come up (as they should)
but on the down stroke it runs past the bottom of the w/s onto the cowl, comes up I turn off the switch and they park at the bottom where they should. In order to eliminate the over run
on the bottom I have to position the wiper arm about 4" up from the bottom. Any suggestions. Could it be that I cut the motor arm threads at the incorrect clock position?
I did not clock the Honda motor. I should have wired it with the relay first then connect the Honda motor, cycled it to the park position then made the cuts on the shaft to line up with the Z wiper arms. I happen to have an extra Honda motor so back to grinding.
Edited by chiefmd
