Does anyone have any spare or a lead to who supplies sets of main jets for the triple SK carbs? I preferably need size 150, 160 and 170. I thought Mikunis where compatible but they're not. The jets I have now were drilled out more by the previous shop and been running really rich.Thanks in advance.
Edited by 240Ziggy
https://www.classiczcars.com/forums/topic/55780-triple-sk-main-jets/
You can always solder them up and re drill them to the size you need, it's dead simple and when you find the jet size that works the best then you buy the proper jet, although many guys run soldered jets and never have a problem.
You'll need a set of jet drills, they don't cost much but if you are near my place any time soon you're welcome to    borrow mine.
Chris
Thanks guys. Geeez 10 bucks per jet in US dollars, it's triple the cost in Japan! I guess it's a waste of money to have spares i'll probably never use. I may have to try grannyknot's advice first.
