I need these parts for a 71 (2/71 ... series 2) just in case you have them … ash tray, heater lever button, vent knob, and hatch piston (that holds the hatch open
Edited by Tomcat
https://www.classiczcars.com/forums/topic/55796-1971-240z-parts-needed/
8 hours ago, SteveJ said:
im curious. is that for a single strut, or the dual strut hatch?
6 hours ago, Namerow said:
Ashtray lid and Heater control knobs available at http://www.240zrubberparts.com .
Thank you on the heater control knob. I have the lid but the tray itself is broken ... the area of the pivot pin on the right side that the lid mounts to. There is also a spring for the lid I do not have.
My ashtray suffered from exactly the same problem (design flaw).  I rebuilt it and the results came out quite well.  If you're unable to find a replacement unit and you're interested in giving it a try, let me know and I'll post some pictures of the rebuild.
  • 4 weeks later...
The ones I have found are so expensive that I would like to see if your repair is something I can make work for me.
Give me a day or two to pull some pictures together.
