Posted April 10, 200322 yr comment_33393 Hey guys, i just purchased my first Z , and we all know i want to start modding it after i tune it up and and clean it. i was hoping for some insite about the car. its a 1978 280Z non-turbo FI. Just wondering wut kind of 1/4 mile times, 0-60 times and hp and torque ratings it has stock. Also wut is the best way to go, get all the parts to turbo it, or go all engine (intake, ignition, plug wires, exhaust, header, pistons, cam, maybe bore, etc.) Thanx for all ur input Link to comment https://www.classiczcars.com/forums/topic/5584-engine-or-turbo/ Share on other sites More sharing options...
April 10, 200322 yr comment_33449 Torque 163 FT-Lbs @4,400 RPM Horsepower (SAE) 149 BHP @5,600 RPM 0-60 MPH 9.4 Sec Curb Weight 2875 Lbs probably eiser to swap a L28ET in than convert your L28E in to a turbo Link to comment https://www.classiczcars.com/forums/topic/5584-engine-or-turbo/#findComment-33449 Share on other sites More sharing options...
April 11, 200322 yr Author comment_33458 Thanx Ivan!I could still use a couple other Z owners opinions about anything havin to do wit moddin up my 280z. I'm not sure if this is correct but i found these numbers for a 1978 280z coupe on www.zhome.com. are these numbers reliable?? 78 Z (5 spd) 0-60 8.0 16.6@84 --- top speed-121 Bhp149@5600 Ft/lbs163@4400 curb weight=2780lbsplease give me ur guys popinions on the mods and the numbersThanx alotAndrew Link to comment https://www.classiczcars.com/forums/topic/5584-engine-or-turbo/#findComment-33458 Share on other sites More sharing options...
