Posted July 22, 20168 yr comment_499305 You know those 2-pin electronic flashers that you can get? I would like to know more about how they work, so you could use it for other stuff besides flashing the turn indicator lights. I have a few in the parts box. Most of the stuff I read involves plugging them into your motorcycle, but could you just hook it up to a 12V battery to flash some lights, like on a sign in the front lawn? If you used the old-fashioned bimetal flasher, you need a lot of current or resistance, but would it work for just a few LEDs? The one flasher I looked at had only the B and L terminals. Edited July 22, 20168 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/55843-using-a-2-pin-electronic-flasher-unit/ Share on other sites More sharing options...
July 31, 20168 yr comment_499910 I have one that's has adjustable rate. Works great. Should work for your idea. Good luck. Link to comment https://www.classiczcars.com/forums/topic/55843-using-a-2-pin-electronic-flasher-unit/#findComment-499910 Share on other sites More sharing options...
August 1, 20168 yr Author comment_500020 You just put it in-line with your lamps? The other ones (with 3 terminals) need the earth wire too. Link to comment https://www.classiczcars.com/forums/topic/55843-using-a-2-pin-electronic-flasher-unit/#findComment-500020 Share on other sites More sharing options...
August 5, 20168 yr Author comment_500290 I had success using the 2-pin electronic flasher with a chime unit from a Yundai. It goes inline with the +12V supply, then to the chime, as in this diagram: The chime now provides a pleasant and steady ding-dong ding-dong sound. The only thing left is to assemble it and add a connector, then install it as a lights-on reminder in place of the current one. Oh- Thanks to Captain Obvious for the tip on using the Yundai chime. Edited August 5, 20168 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/55843-using-a-2-pin-electronic-flasher-unit/#findComment-500290 Share on other sites More sharing options...
