Hey guys I'm brand new to the forums. I've been wanting to get an S30 for a while now just haven't been able to find one for the right price. I just wanted to get your opinions on this car I'm looking at. Looking at the add he obviously doesn't like people asking about rust on his car but says the frame is good and the car will run. Is it worth it? Body work and stuff I can deal with I just don't know how much structural damage there might be without actually getting to look at it myself and I'm pretty far away from where he is at. Any help would be appreciated thank you.
https://seattle.craigslist.org/tac/cto/5623188033.html
https://www.classiczcars.com/forums/topic/55856-is-it-worth-it/
Possibly, these cars are appreciating rapidly so project cars are getting a lot more expensive. This would have been a couple of hundred bucks 5 years ago. This is a serious project though!!!! You need to figure there is twice the rust than what you can see. If you're up for the welding work and have the money, time and resources by all means. Really good floor boards are available from Charles Osbourne. The battery tray metal is not available after market. I would find a donor car for that metal, at least the battery tray. I have fabricated that metal under the battery tray and it is hard to make from flat sheet metal...
Well I like a challenge as long as it is something that I can fabricate and work on myself. My only concern would be money when it comes to where I find a big problem that I wouldn't be able to fix without some pre-made parts. Otherwise I have no problem with taking the time to work on it. I'd rather drive something that I've worked on. Thanks for the quick reply also.
Do you have the tools to do this kind of work? A good place to work? A good welder? How limited are your funds? The floor boards are $300 or so. The battery cut will be close to a $100 probably. Then there is a lot more to spend money on, so don't get into this if you won't have several thousand to invest in this on top of the car cost, at least to get it driveable. I am sure there will be lots of surprises. The doors are shot. I would suspect the rockers need work, the dog legs, rear wheel wells possibly...I would not trust his description for the front frame rails either
Doesn't look terrible.  Says it has clean title and plates.  Sounds like he might take a lower offer.  You might ask about the fiberglass - " PUT THE TAILIGHTS BACK IN WITH A LITTLE FIBERGLASSING ".
What are your plans is the question.  Engine swap hot-rod?  Restore for car shows?  Ratty daily driver?
Towing to Vancouver might be costly.  Which Couve?
I mainly want it for a daily driver, it doesn't need it to be show car quality. If I were to get it I would drive up with a trailer and pick it up. And yeah I didn't think I was going to trust what he says the condition the frame is in. I suspected at the least there was still going to be some work to be done on it.
People are asking about the rust because he is only showing a little bit here and there, I'll bet there is a LOT more.
With all the fiberglass on the rockers and rear end is impossible to tell what is solid or not, also there is no frame on these cars regardless of what he says, it's all connected. Be careful when you go look at it, check the doglegs thoroughly. The engine is basically worthless for resale, you can't give away 2.4L engines and the 5 spd tranny is worth about $300 so no, the engine and tranny aren't worth what he is asking for the whole car.
If you go see the car maybe take some pics of the areas that he isn't showing, we would love to see them, good luck. Oh, and welcome to the forum, lots of good info and people here.
Chris
 There's too much wrong with it for that price.  Don't get in a hurry to buy a Z. You'll spend far less time and money and be on the road sooner if you use the money that would have gone into this one to get one in better shape. Many sheet metal parts are available but it is very discouraging when you open a Z up and find the rust keeps going and going. The battery area rust could and probably does include the firewall and the front frame rail. I also don't trust bondoed flares and such mods. They can hide rusted out quarter panels. Also the flex and twist in these bodies will crack thick Bondo. That said, I would consider it if it didn't have the flairs.
There's a lot of rust that we can see and I'm sure there's more that we don't see. Those side skirts are usually installed to hide rusty rockers. It looks like in pic #11 there's some filler above the left tail light. Has anyone ever seen a blower motor housing that rusty? Sandblasting the roof may have caused warping. I wonder how the rust is in the door jams and cowl. The engine/trans would probably sell for $500-1000 as-is. Maybe less based on how he presents himself. Since fixing the rust is "SIMPLE" maybe he'll fix it for you. LOL
Chuck
